Originally Posted by Quest
air-cooled, side valve engines shall always run a tad rich and have carbon deposits on the top of the piston (or combustion chamber) no matter how meticulous you try to keep it clean. Compounded with carburettor system, these "crude" engines will never run clean no matter how hard you tried.
Don't waste time on gas additives. Simply (a) run fresh gasoline very time, and (b) schedule to pull the head and scrape the carbon every 100~200hrs.
Q.
You might get 1/8th of that run time before main jet gets clogged. I've heard that even TCW-3 can help stabilize the fuel and also keep the carbon deposits to a minimum.
Originally Posted by das_peikko
Originally Posted by Festiva_Man
I was hoping to avoid that
never taken a carb apart before, i would probably put something back togeather wrong.
You'd be surprised by how simple they are and how few parts they have. You'd also be surprised by how simple they work.
Main jet is usually a single fastener to remove the bowl, and then the jet screws into the bowl. Easy as pie, you dad didn't teach you how to do it because it was not an issue before they started irishing up our gasoline.
