How to use Techron fuel system cleaner??
I haven’t seen this discussed but I always thought that it was best to use a fuel system cleaner like Techron when you’re doing just every day stop and go driving in which a tank of fuel would be consumed over a longer period of time. My thought was that this is better than just putting it in prior to one long distance drive in which it is entirely consumed in one trip. Thinking the stopping, turning the engine off, letting it sit overnight soaking etc. would allow the cleaner to perform its desired function better. Does that make sense? And let me know if this has been discussed. Thanks.
It would make sense that having the cleaner sit and soak many times over a tank would be more effective than a long highway drive all at once. With that I would say a mix of both stop/start and some good freeway miles would be ideal and a few full throttle runs might be good too!
When I’ve had an injector issue, overdosing Techron into Shell V-Power or similar & taking a long highway run has fixed it. Occasional maintenance doses, it doesn’t seem to matter-but I run nothing but TT (Shell, Sunoco, Marathon) and BP/Amoco anyway.
Here are a few discussions which may be helpful in regards to long vs. short trips. One is pretty recent:
