Here is the recommendation for a 2013 Subaru BRZ. In the "Additional Information" insert section they have
Quote:
Fuel
Use premium unleaded gasoline with an octane rating of 91 AKI or higher.
And then later in the manual
Quote:
Fuel types
Unleaded gasoline (93 AKI [Research Octane Number 98] or higher)
If unleaded gasoline with an octane rating of 93 AKI (98 RON) is not available,
unleaded gasoline with an octane rating of 91 AKI (95 RON) may be
used with no detriment to engine durability or driveability.
And the 2012 Corvette
Quote:
Recommended Fuel
If the vehicle has the 6.2L V8 engine
(VIN Code W), use premium
unleaded gasoline with a posted
octane rating of 91 or higher.
You can also use regular unleaded
gasoline rated at 87 octane or
higher, but the vehicle's acceleration
could be slightly reduced, and a
slight audible knocking noise,
commonly referred to as spark
knock, might be heard.
If the octane
is less than 87, a heavy knocking
noise might be heard when driving.
If this occurs, use a gasoline rated
at 87 octane or higher as soon as
possible. Otherwise, you could
damage the engine.
If heavy
knocking is heard when using
higher, the engine needs service.
(VIN Code T) or the 7.0L V8 engine
(VIN Code E), use premium
For best performance, use premium
octane rating of 93.
In an
emergency, you can use regular
rating of 87 or higher.
If 87 octane
fuel is used, do not perform any
aggressive driving maneuvers such
as wide open throttle applications.
You might also hear audible spark
knock during acceleration. Refill the
tank with premium fuel as soon as
possible to avoid damaging the
engine. If heavy knocking is heard
when using gasoline rated at
91 octane or higher, the engine
needs service.
Just thought it was interesting how they are all worded.
