Kestas
Staff member
Originally Posted By: onion
Originally Posted By: Kestas
Bearings, including CV joints, are not replaced in pairs. When that kind of work is done under warranty, it is not authorized to replace in pairs unless both sides are diagnosed to be bad (which happens only rarely).
They aren't wear items in the traditional sense of "wear". They either work or they're bad.
So if a front wheel bearing (let's say on a '94 Chevy Corsica) fails at 170,000 miles, then you would only replace the failed bearing? 'Cause the other might have quite a lot of life in it?
What if the 'other' bearing was slightly loose (only slightly), but otherwise smooth and trouble-free?
Let's see... '94 Corsica... 170K... one bearing fails. The technical answer is the same as I previously stated. That bearing must be replaced.
As far as the other bearing being slightly loose, you still have to take each bearing on its own merits. You have to ask why the bearing is slightly loose. This goes for sealed hub units as well as serviceable tapers. Like I said, bearings don't wear in the traditional sense of wear. I've had to argue this point many times with people who intuitively insist that bearings can wear. If a bearing shows wear it is bad and must be replaced.
