100% correct, my mistake. D4 is the dex III.Isn’t D6 a dex VI?
I tried it in a couple of old Subaru 4EAT units and it shifts very soft, it isn't good. Amsoil ATF is a much crisper shift and last a lot longer. I still use Amsoil in some units and TES-295 in dex III spec applications, it is a huge improvement over Maxlife.I have no negatives to report other than like mentioned above, the sink from the stuff. I've used it in several GMs, FCA, Honda, Hyundai, Nissan, Subaru and Toyota applications. Maybe more.. These were my own vehicles or family member's.
@TravI tried it in a couple of old Subaru 4EAT units and it shifts very soft, it isn't good. Amsoil ATF is a much crisper shift and last a lot longer. I still use Amsoil in some units and TES-295 in dex III spec applications, it is a huge improvement over Maxlife.
Hmm, interesting. I assumed the fluids would be very similar, but I guess that might not be the case. I'm still trying to decide what to use in ZF 8 speed.I tried it in a couple of old Subaru 4EAT units and it shifts very soft, it isn't good. Amsoil ATF is a much crisper shift and last a lot longer. I still use Amsoil in some units and TES-295 in dex III spec applications, it is a huge improvement over Maxlife.
This is contrary to what I saw in my research. Many have used it in Pilots with good results.ML worked great in my old Infiniti. OTOH, I tried it in my Pilot and it caused weird shift flares. Went back to factory DW-1 and the shifts were smooth again. I was surprised because ML seems to be well-regarded amongst Honda owners.
If it is a dex III unit I absolutely would. TranSynd, BP Autran Syn 295, Mobil Delvac 1 ATF are all good as I am sure many others are that meet the spec. Amsoil ATF and Redline D4 are also very good dex III clones not the ATFL or D6 those are dex VI clones like Maxlife. Notice neither tries to pass their ATFL as a dex III compatible fluid like Maxlife does.@Trav
Would you recommend TES-295 in a 1994 Honda Accord automatic ?
Which brand would you go with for TES-295?
That is my complaint about Maxlife, their desire to pass this stuff off as a one fits all product. It works but is it really the optimal fluid for many of the applications listed that are not Oe spec for a LV fluid, I highly doubt it.
How can the Amsoil be used in Mercon ULV?Now look at the ones for ATFL, they do mention GM themselves back spec'd dex VI for dex III in GM transmissions but GM are not the only ones using dex III spec fluids.
Use AMSOIL Signature Series Fuel-Efficient Synthetic ATF in transmissions and other applications that require any of the follow-ing specifications:Aisin-Warner AW-1; BMW 83 22 0 142 516, 83 22 2 152 426; Chrysler MOPAR* 68157995AA, SP-IV, 68218925AB; DSIH 6p805; Ford MERCON* LV, SP, ULV; GM DEXRON* HP, DEXRON* VI, ULV; Honda/Acura DW-1*, Type 3.0; Hyundai/Kia SP-IV, SPH-IV, SP-IV-RR, NWS-9638, SP4-M; JASO 1A-LV; JWS 3324; Mazda ATF FZ; Mercedes Benz 236.12, 236.14, 236.15, 236.41; Mitsubishi SP-IV, ATF J3, ATF-PA, ATF-MA1; Nissan Matic-S, Matic-W; Saab 93 165 147; Shell M-1375.4, M-1375.5, M-1375.6, M-L 12108; Toyota WS; Volvo 31256774; VW/Audi G 055 005, G 055 162, G 060 162; ZF S671 090 255.
When GM bought out Allison they back spec'd Dex VI fluid for the Allison transmissions along with the other GM dex III units and the dealers were repairing more than a few failed Allison transmission due to seal failures.
The point is just because GM said it would work okay it didn't.
Call me cautious but if it not a GM built transmission I will not assume using a LV fluid in a dex III unit is going to be optimal.
I’ve heard of people using it in their Jeeps. I’ve also heard “DexIII”and ATF+4 are very close in formulation. That said, no thanks.It worked well in my 2000 Century, but I won't chance using it in my two ATF+4 spec'd Jeeps. I can get ATF+4 cheap enough not to even think for a split second to try it in one of them.
+1I’ve heard of people using it in their Jeeps. I’ve also heard “DexIII”and ATF+4 are very close in formulation. That said, no thanks.
The correct fluid is cheap.
nobody has ever said that, everI’ve also heard “DexIII”and ATF+4 are very close in formulation. That said, no thanks.
atf+4 is on a different planet
I've also heard and read the same thing unfortunately.nobody has ever said that, ever
Unless it comes from a reputable firm I wouldn't trust some random people on the net.I've also heard and read the same thing unfortunately.
