SomeONE at work made it.
Quote:
______________________________________________
Sent: Monday, February 02, 2009 10:11 AM
Subject: FW: Bacon Explosion Recipe with comments -- PS
The recipe says make a 5 X 5 strip mat with the bacon.
I using Albertson's thick cut bacon from the butcher block, and wound up with a 6 strip x 7 strip mat, in order to make it come out even. So it wasn't exactly a square but it certainly worked well.
C
Sent: Monday, February 02, 2009 10:09 AM
Subject: Bacon Explosion Recipe with comments
http://www.nytimes.com/2009/01/28/dining/281brex.html
This is the recipe that I used ....
,,,although I did use 2 lbs. of italian sausage instead of the 1.5 lbs that the recipe calls for. (There's another version of this on the web that does call for 2 lbs., and Albertsons only had 1 lb. packages.)
...used hot italian sausage
...used KC Masterpiece Hot & Spicy BBQ sauce and McCormick's "Steak Rub"
...took 4 hours in my oven at 225 deg F.
Enjoy.
C
