I'm getting pretty confused. What was the VII polymer trumpeted not too long ago, then? I will share that star VII polymer was endorsed by a very knowledgeable lube mfg. How can it be both great and terrible? What is OCP?
First of all
permanent shear is an entirely different phenomenon than
temporary shear, the latter of which the A_Harman index measures and the HTFS (BO DV150) takes into account.
High permanent shear does
not mean high temporary shear and vice versa. Hugh Spikes et al. paper linked above is a
tour de force discussion of temporary VII shear.
In permanent shear the VII molecules are permanently deformed or broken under very high shear rates such as in the valvetrain and timing chain and no longer contribute to the viscosity even after the shear rate goes back to zero.
In temporary shear the VII molecules temporarily and either partially or fully align themselves with the flow, temporarily reducing or eliminating their contribution to the viscosity. Once the shear rate is reduced to a low shear rate, their shapes are not altered from the original and they fully contribute to the viscosity.
What the tech-support guy told you about the hydrogenated-styrene star VII is permanent shear, not temporary shear. These star VII's are
high-(permanent)-shear-stable but
low-thermally stable, i.e.
dirty, VII's. They retain their viscosity boost well in the long run, but they form more engine and turbocharger deposits, as they run dirty. They are more popular in HDEO application, where viscosity and permanent-shear stability is more important than engine deposits.
On the other hand, olefin copolymer (OCP) linear VII's are
mid-(permanent)-shear-stable but
high-thermally stable, i.e.
clean VII's. They experience moderate permanent shear, but they run much cleaner. They are very popular in high-performance PCMO applications as well as most other PCMO applications as a result.
I discussed a nice article about the deposits caused by star and OCP VIIs:
GM turbocharger test: No correlation for deposits with TEOST 33C or moly
I never understood why GTL is API Group III base stock. Mobil taught us in the world of PAO (now Group IV) they were made from ethylene gas which was derived from methane. Reacted in a hydrotreater to truncate the linear hydrocarbon at desired length (viscosity). Mobil made 3 or 4 base PAO stocks, blended to fit product spec. How can GTL not be API Group IV? Mobil fought against hydrocracking being called "synthetic".
Too many marketing games.
Group IV is synonymous with PAO, which is a laboratory-synthesized base oil. You can't classify any other base oil under Group IV, but all other laboratory-synthesized base oils are classified under Group V.
GTL is a hydrocarbon-based base oil, and it is classified under Group III—Group III+ to be more precise.
The
main difference between the petroleum-based traditional Group III and natural-gas-based GTL Group III is the
feedstock—petroleum-derived slack wax vs. natural-gas-derived wax, respectively. The rest of the process involves either catalytic or solvent dewaxing and a lot of hydroprocessing, which is also the same for Group II. The quality of the base oil depends on the severity of the hydroprocessing, which decreases both the CCS and Noack and increases the viscosity index (VI). As the process becomes more severe, you go from Group II to II+, III, III+, III++, III+++, III++++, and so on. The higher the group, the more the oxidation resistance the base oil has, which results in longer OCI's and cleaner engines. Therefore,
not all GTL base oils are equal, and Sasol is competing with Shell.
Sasol says, with the GTL technology, a Group III+ base oil can be made as cheap as a Group I base oil (highly refined mineral oil (
dino base oil)).
The processes after "waxy lube oils" should be the same for Group II, Group III, and GTL:
![[Linked Image from mcdermott.com]](https://www.mcdermott.com/getmedia/ba02a0a8-bc8d-49c9-8a2a-3de9acb36a5e/hydroprocessing.aspx?.gif)
This is the same as above, except solvent dewaxing is replaced by catalytic dewaxing, which is what Shell uses in its Pearl, Qatar GTL plant:
![[Linked Image from media.noria.com]](https://media.noria.com/sites/archive_images/Backup_200305_IndFocII-Fig2.gif)
