I presume, given their stated product names, that the Extended Protection is meant for longer OCIs?
I'm a lubrication enthusiast who enjoys diving into the details for fun, not as a job. While ATF (automatic transmission fluid) isn't the same as motor oil, I find both fascinating in their own ways. The filtration process in automatic transmissions is quite different from engines. The wear protection difference between a high-quality ATF and a premium ATF is small but noticeable. For daily drivers who don't push their cars hard, tow, or haul, there's really no significant difference between Valvoline MaxLife and Valvoline Extended Protection ATF.
But if you track your car or drive it hard, keeping the transmission under high torque, Valvoline Extended Protection can make a real difference. It’s not just about extending oil change intervals; it's about pushing your transmission harder without damaging it.
The additive package in Valvoline Extended Protection is the same as what's in Mobil 1 LV ATF HP (Dexron HP), Motul ATF VI, and all TES 668 licensed fluids. When I was looking for a better, easily available, and reasonably priced replacement for Hyundai SP4M and Lifeguard 8 fluids, I found that Mobil uses Infineum's top-notch stepshift automatic transmission fluid additive package. It took Infineum years to develop this universal package for all stepshift automatic transmissions, resulting in smooth and quick shifts. To get the full benefit, you'll need to reset adaptive values and trigger a relearn after switching to this fluid.
I also looked into TES 668 for transfer cases and noticed that the elemental composition of Delvac 1 668, Castrol TranSynd 668, and Valvoline Extended Protection ATF were almost identical, indicating the same Infineum DI package. This was confirmed by
@Foxtrot08, who said Infineum supplies additives for all TES 668 fluids. It seems Infineum has nailed it with the best universal additive package for stepshift automatic transmissions.
For Valvoline MaxLife, they switched from Lubrizol to Afton Chemical. Afton had already developed an additive package that works in both stepshift and CVT automatics, which Castrol first used in their TransMax fluids. Now, you can find these products side-by-side in stores.
While Infineum's additive catalog and blending guide are hard to access, Afton Chemical shares a lot of information on their website. I'm pretty sure the DI package that Valvoline and Castrol use for their universal transmission fluids comes from Afton:
