I'm sure most of us know what a PITA checking the ATF level is, especially after a flush or drain/fill. Well, this tip isn't for getting an accurate level, but for future reference. Once you are happy with the fluid level, check the level again with the vehicle cold and off and memorize/make a note of where it is. That way you can always check the fluid level first thing in the morning (or after the vehicle has sat for a while) without having to start the car and drive around hoping the fluid is at a check-able temperature. I finally got my level to where it was with the vehicle cold and off from the factory. If anyone has any reason why this may not be a good idea, please feel free to chime in as I don't want to give bad advice. Like Scotty Kilmer said, "If it shifts good, it's right." ;-)
