Hi all, i just did a transmission drain on my 06 nissan titan for the first time. And now, im checking the transmission dipstick for the first time also just to make sure i added enough fluid in. It seems like im a quart low. But, since im a newbie at checking the transmission level, i need help deciphering my service manual on how to check the fluid level. i understand it's not the same as checking the engine oil (turning off the engine and waiting for 10 min. to look at the dipstick). I believe for the transmission, i have to let the engine idle on "park" after driving the vehicle around? This is what is confusing me a little bit...
Can someone tell me if im doing this right?: I start the engine, drive around for a good 30 mins., park the car on a level flat surface, let the engine idle for 2 mins, and then pull out the dipstick on the "Hot" side to check it..? It would read right at the add mark on the "Hot" range.
Here's what my manual says about using the Hot range:
1) Drive the vehicle to increase ATF temp. to 80 C (176 F).
2) Allow the ATF temp. to fall to approx. 65 C (149 F).
3) Recheck the fluid level at temp. of approx. 65 C using the HOT range on the A/T fluid level gauge (dipstick).
To use the COLD range:
1) Start engine and move selector through each gear, then shift to Park.
2) Check fluid level with engine idling.
3) Check fluid level at fluid temp. of 30-50 C(86-122 F).
Thanks for any clarifications...
Eric
Eric
