I owned several brand of car (Honda, toyota, nissan). On the Toyota, checking the ATF level is easy, it has a hot mark and a cold mark. Nissan is the same thing. However, the honda only has 1 mark (min + max).
The manual say to check the ATF, some where in between min and max. That is all. I read some where and they recommend that checking the ATF when the car is HOT and RUNNING, shift from P -> 1 twice then check the fluid level.
I measured the car when I cold, not running, the ATF is way over the max (about 0.25in) but when I try the HOT method, it is in the middle of min and max.
I know that ATF should NOT be overfilled in any case so what is the RIGHT way to check ATF when your car has only 1 mark?
Thanks!
Thanks!
