Oilgal
Thread starter
Originally Posted By: Rick20
Oilgal,
Is it possible that your oil filter is loaded up again. I ask this because you had previously mentioned on other threads that you felt the need to replace oil filters fairly frequently during the original rinse phase of your first application. Now you were 400 miles into a second cleaning before adding the second bottle, trying the double dose. It may be possible that the filter was pretty close to blind from the first 400 miles of this application. I wonder if possibly your filter is in the bypass mode and messing with good oil circulation or flow. It may be worth checking?
BINGO
You are right about the filter issue. I checked it today, and it was very heavy after I poured out the viscous black liquor it contained. I bet it was very flow restricted. Really though it was early this morning, that I finally got around to actually adding that second bottle of ARX, and I also finally figured out that I am really 500 miles into my second treatment.
One other thing of interest.
Taking a good look inside, the oil fill port on my valve cover, revealed that most of the varnish is now gone finally. Now that was really nice to see.
Oilgal,
BINGO
