2012 Mazda3 Brake Issue
DFW
After 140,000 miles on the original pads it was finally time to replace the fronts. My choice of replacement was Bosch QuietCast Ceramic. The rotors were both within spec and there wasn't any noticeable lateral runout. So, this was just a pad replacement, like the many others I've done in my life. The job went well with no hitches. I cleaned everything, lubed the correct spots where the pad tabs contact the caliper bracket. I cleaned and lubed the slide pins and made sure the bracket bolts were tight. The new pads were already backed (shims) and came with new stainless steel retaining clips.
I now have a clunk/pop sound coming from one of the front wheels whenever I step on the brake pedal. It's annoying, for sure. A week afterwards I replaced the brake fluid. (I didn't have enough to do it when replacing the pads.) I had all four wheels off and checked and double checked the front brakes. Everything looks perfect and is functioning as it should. I just have the noise. If these pads just aren't a good fit I don't plan to screw around trying to return them to RA. I would just buy a different set. I've just never had anything like this happen before.
Has anyone experienced this specific issue and, if so, how did you resolve it? TIA
I also should mention that the inboard pads actually snap into the pistons with three pronged clips riveted to the pads. I keep thinking I'm missing something obvious.
I also have a Mazda 3 (2011) with replacement Bosch pads on front and get a predictable front end clunk when putting the car into reverse and easing up on the brake pedal.
Pads went on 3.5 years and 27,000 miles ago. Bosch "blue" BE1044, which have otherwise been worth the $16.62 paid.
Perhaps I take it apart this winter and discover a missing clip or loose caliper bolts.
Take it apart again. Check pad fitment and torque fasteners per spec. Good
I'm thinking that the tabs on the pads fit either too loosely or too tightly in the caliper brackets. I did lightly grease those areas with the included synthetic grease. If the fit is off, though, they could still "stick." I only hear the noise when the brakes are warmed up, not for the first mile, or so, of driving. The brakes are working well so dealing with this isn't urgent, but if I get ambitious I'll either try a different brand of pad, or possibly smooth the edges of the tabs on the current pads slightly.
Aftermarket Pads are fitting too loosely - need to buy the dealer pads. The issue seems to be more prevalent with this type of caliper since it does not use clips on the bracket.
Thanks, Don. I did check everything for tightness when I had the front wheels off again a week later to bleed the brakes. The lug nuts are all torqued correctly.
Here's something interesting. The calipers and pads on the car said, "FoMoCo." I cross referenced pads and both the 2012 Ford Focus amd 2012 Mazda3 used the same front brakes. The OEM pads from Ford are $46. The OEM pads from Mazda are $115. WTH? Both vehicles use the same aftermarket part numbers on Rock Auto, too.
Friction material is different on the mazda application. The Mazda pads did say Fomoco, but used NBK material per the stamping on the backing plate.
I'm ordering the OEM pads at 4x the price. Given how long they last I guess I'm not gonna sweat the $100. The sound I hear when stepping on the brakes has already become old. I've never experienced this before and I've done a fair amount of brake jobs in my life.
Our Mazda 5 had Fomoco pads too and lasted beyond 60k but I replaced them any way with new pads. We now have 160 k on those replacements and they are only half worn.
I have a 2023 Mazda 3, only 22K on it so far, but was wondering what I would use for replacement pads when the time comes. This thread is making my eyeballs hurt. I have always preferred Bosch Quiet-Cast in my cars. Never had an issue with them. Inexpensive, quiet, long lasting and low dust. What's not to like? The 2023's don't use the same size pads as the 2012, so must have been some sort of change down the line. I still may try it, but if I get the same noises, I'm out.....
Review on Amazon for the Quiet-Cast pads that fit my 2023: (YIKES!) - Maybe I won't buy them.....
  • Like
Reactions: TCL
I've used better quality semi metallic and ceramic aftermarket pads on about a dozen vehicles in my life and have never seen anything like this. Apparently there's a reason that the Mazda pads cost multiple times the cost of even the higher cost aftermarket bits.
The aftermarket belt tensioner (Gates) that I installed in 2021 has been a disappointment as well because the belt sometimes squeals, even after replacing it twice (Gates and Bando). Perhaps it puts inadequate tension on the belt. Guess I'll eventually replace that with OEM as well.
Mazda buys the pads from ford, then marlks them up. Seen that a lot over the decades
I just installed the OEM pads. I'll report later to confirm whether or not the noises are gone. There were two noticeable differences between the Bosch and OEM pads.
One was that the edges of the tabs were finished a bit smoother on the OEM pads. Two was what I think was the most significant. On the OEM set the outboard pads riveted-on shims included a bit of wraparound that covered the underside of the tabs. It either makes the pads fit the brackets more tightly or provides a friction surface that is not the backing itself.
