I have 2 ..
The bike RUNS fine on 10% ethanol. My concern is storing the bike with this fuel in the carbs. I've been told by a professional mechanic of 30+ years that leaving a bike stored with ethanol fuel in the carbs will cause seals to deteriorate, and moving parts to gum up. It looks like there are others who support this notion. You apparently have experienced the opposite. I'm not doubting that. I will say I think there are fewer possible downsides to draining, as opposed to leaving the fuel in...My original point is that ethanol fuel has been available for at least 40 years. It would be reasonable to expect a 1998 model bike to be able to run on 10% ethanol fuel and for that to not cause damage to the fuel system.
The owner's manual (this one is from 1997) was written before ethanol was as widely used as it is today. As long as the fuel level is lower than the top of the float bowl (once the engine is run until it quits), it will be below the needle seat...Does the owner's manual say anything about the issue?
A fuel injector that is "dry" can stick closed. I've had it happen. (The fix was to tap on it with a wrench to free it up). The cause seemed to be the stuff in gasoline that doesn't evaporate and leaves a sticky deposit.
Presumably, the same thing could happen with the needle and seat on a carburetor that is drained but not drained well enough to get every last drop of gasoline out of it, unless perhaps you flush it out with solvent of some kind to get that last bit of gas out of it.
Unfortunately, the bowls and fuel lines on my bike aren't accessible without doing a lot of disassembly, so I'll just run them dry...I'd remove the bowl to make sure it's empty, and disconnect and plug the fuel line so any residual fuel that might still be in the tank doesn't fill the bowl back up as it drains off the sides of the tank over time. And maybe spray some WD-40 into the fuel inlet on the carb.
My problem with draining the bowls is that the float needle seal will dry out and the floats could stick open as well as possible oxidizing of the aluminum and brass if moisture gets into the carbs. I feel storing with good fuel (E0 if possible) that's stabilized is my best option.
That must have been a lot of gas that dried up in those carbs. What did the bottom of the bowls look like?
Sits for just a few days? Gas isn't that bad these days. Seems a bit over board to drain the carbs if the bike sits a few days.If my '82 carburetor bike is to sit more than a few days I shut off the gas and run it until it quits and then open the drain on the bottom of the carb to drain anything left. Never have an issue.
Fuel is in the carbs 100% of the time when it's being used, so if E10 caused "seals to deteriorate" then that would be true regardless if the bike is sitting or running. Sounds like a misconception by the "professional mechanic" to me.The bike RUNS fine on 10% ethanol. My concern is storing the bike with this fuel in the carbs. I've been told by a professional mechanic of 30+ years that leaving a bike stored with ethanol fuel in the carbs will cause seals to deteriorate, and moving parts to gum up. It looks like there are others who support this notion. You apparently have experienced the opposite. I'm not doubting that. I will say I think there are fewer possible downsides to draining, as opposed to leaving the fuel in...
Fuel is in the carbs 100% of the time when it's being used, so if E10 caused "seals to deteriorate" then that would be true regardless if the bike is sitting or running. Sounds like a misconception by the "professional mechanic" to me…..”
I store my bikes hot and wet! Including my carb'd DR650.I have a '98 Honda Super Hawk that has carbs, and I've been told to make sure the carbs are dry when in storage, as today's gas with ethanol is supposed to be bad on them. I've always stored my bikes over the winter with Sta-Bil in the fuel systems without problems, but these were all fuel injected bikes. A local mechanic of over 30 years (he claims) told me loves when people leave gas in their bike's carbs because it brings his shop a lot of business rebuilding carbs. How do you store yours?
I think your good fortune is due to you using ethanol-free gas. Gas treatment helps...I store my bikes hot and wet! Including my carb'd DR650.
I've never drained a carb, and all my engines start without issues every season.
HOWEVER.... I always use 91 octane (ethanol free here) and treat gas with a double dose of stabil and MMO. Small engines always run treated gas, motorcycles get the treated gas on the last couple of rides before the tank is topped off, battery tender connected, and bike is parked.
Your mechanic isn't wrong... those that don't follow my regiment will likely be visiting the local small engine shop for "maintenance". Neighbour of mine bought same snowblower, same year, and he's junked his already. Mine runs strong, smooth and starts easy after 13 years. In fact, it's freezing here now... time to pull her out, remove the cover, prime and I bet she starts on first pull![]()
I've never drained carbs when using E10 ... did it for 20 years with no fuel stabilizer and have never had a problem. My 35 year old Craftsman lawn mower still fires up fine every spring. Maybe it has to do somewhat with the brand of gasoline used? ... Chevron is what I've used for decades. The carb has never been touched. I've only started using fuel stabilizer for winter storage in my stuff over the last 3-4 years.I think your good fortune is due to you using ethanol-free gas. Gas treatment helps...
