tbm5690
Hibernation has been initiated
If that's been working, which it should, then keep with that process.I always store the bike with a full tank of stabilized E0 fuel, and I ensure that the treated fuel has made its way through the carbs as I add stabilizer the tank prior to my last fill-up as well. I store my bike for 6 months in a heated garage at 50F.
Yup .. Same here in WI. Although leaves are starting to hit the roads, it's not officially over until salt hits the roadsNot there yet here in central PA, few more rides, but by end of Nov. for sure.
I use a low wattage air circulator made for boat storage under my covered bikes during the winter just for that reason.Keep in mind not to wrap the bike too tight. Condensation/moisture can build up and work its way into systems and electronics.
Now I am impressed (not kidding!) Such a device never occurred to me and I have been boating/owned my own boats for many decades. I just did a search and I see what you are talking about.I use a low wattage air circulator made for boat storage under my covered bikes during the winter just for that reason.
Yeah you can't tell from the pic but it's wide open on the bottom and very loose-fitting. Highway bars and windshield keep it away from the body on the front and saddle bags do the same on the rear. Never any issues with moisture.Keep in mind not to wrap the bike too tight. Condensation/moisture can build up and work its way into systems and electronics.
I use something very similar to this. It doesn't have a fan and operates around the clock all winter. It warms the air, keeps moisture away and creates a minute airflow. Bought two of them years ago, one for each bike.Now I am impressed (not kidding!) Such a device never occurred to me and I have been boating/owned my own boats for many decades. I just did a search and I see what you are talking about.
I wish I had an outlet where I store our boat.I use something very similar to this. It doesn't have a fan and operates around the clock all winter. It warms the air, keeps moisture away and creates a minute airflow. Bought two of them years ago, one for each bike.
https://www.amazon.com/Davis-Instru...9046094&sprefix=boat+air+warmer,aps,98&sr=8-3
Get a small solar panel. That should be enough to run a small fan to circulate some air inside.I wish I had an outlet where I store our boat.![]()
Good point, however these devices that @blueglide88 posted also produce a small amount of heat. I think roughly around 110watts.Get a small solar panel. That should be enough to run a small fan to circulate some air inside.
It's pretty breathable and thin, and the whole bottom is open/loose with none of the body of the bike being touched due to accessories supporting the cover. All this to say, plenty of air flow.I would not use plastic cover but soft sheet: old bedding sheet is ideal
