So basically here is a list of everything done in the past month since this bike was not starting last fall...I should also mention that my dad had air filter pods, aftermarket exhaust, and rejetted the bike.
Now I have a few feelings about the carbs and was actually thinking of buying a new whole unit off a local parts bike. The guy said every other part off this parts bike has worked great when ripped onto his working GPZ900. I know the brake cylinders I bought worked!
Now I'm basically assuming there is no gas getting to the engine based on how it sounds. Here's a video and a few pictures of how the carbs are sitting....
eaf35154.mp4 video by sneedham6 - Photobucket
Thanks for the help and suggestions!!!
- Cleaned out tank with POR15 since fuel tank was rusty. Gas came out carb drain screws bronzey looking. After cleaning, inside of tank looked great and gas drained out looking like normal gas.
- Replaced spark plugs
- All pilot screws were at factory suggested amount of turns. Also, there is gas sitting in all 4 of them since I checked to see if gas drained out.
- Carbs all seem well seated into the intake boots; cannot push them in any further as they are right up against the carbs. Would it matter about the angle the carbs are sitting at? They are angled upward and was wondering if they sit more parallel to the ground.
- I have my doubts about one of the vacuum slides; the rubber looked wavy and was not exactly sitting in the groove. Now I don't remember getting carb cleaner on it but am afraid it happened.
