I decided to charge the battery on my Garmin 1370 this morning as I have not used it since the pandemic started.
When traveling, I have no problems using my car built in Navi unit, however I still keep the 1370 on because the 1370 shows the altitude right on the Home Screen.
I like knowing my altitude plus knowing if I’m going up or down. On my built ins, I have to go to different menus to see the altitude.
(BTW; my buddy’s Chrysler 300’s built in Navi unit is a garmin with the car screen showing exactly like a Garmin including the altitude).
As for missing turns when using Navi/GPS, and because GPS/Navi units often send you through roads or streets that you don’t want to use, I always say; “you may use
a GPS, but you still need an MAP”.
IE, have a general knowledge of the roads and areas you want to use.
