Any reason to run an engine after a oil change?
Memory is the reason I changed the oil. My memory is not so well. I change the oil in all my vehicles in the last few weeks. One less thing I have to try and remember. I know when I return to the vehicles they all have fresh oil, and a full tank of gas and Stabil.
Stabil will not keep fuel good for two years
Why would you change oil & filter & not start it to fill filter & circulate the oil.
That first start after sitting for months will be a dry start.
I agree that starting briefly even for a couple minutes is not good particularly for the exahust system where moisture will condense & corrode it.
When I prep for storage wether I change oil or not I drive it to throughly warm it up & dry the exhaust system then shut it down & I don’t start it until I’m ready to put it into service.
90cummins
90cummins
Please help me better understand. Eight liters of oil was extracted from the oil pan. Eight liters oil was refilled through the oil fill opening.
How is a "dry" start after months of sitting any difference is I did or did not start the engine after an oil change?
the pickup tube may have drained due to the empty sump. It would depend on the engine design wether that's a potential issue or none at all. pump in the sump, no issue, pump at crankshaft is another story.
There is no real advantage to not starting it.
There are some advantages to starting it: pump prime, leak check, fresh oil circulation, etc.
Its your truck and your choice. Overthinking things rarely if ever pays off. Crank and run it for a minute or two, check it all out, rest easy.
What's the reason not to start the engine after an oil change?
Regarding a few tens of milliliters of fuel lost: you can replenish the lost fuel. After 2 years of storage all the fuel in the tank will be unusable anyway. You'll need to drain it all and replace with fresh fuel unless you want detonation to destroy your engine.
Also, I don't see a point in doing an oil change before storing the car. You'll put in fresh oil which will surely oxidise and degrade sitting 2 years in the sump. I'd just drain the old oil out and leave it dry. If you have memory problems, then pull out starter relay fuse and put a warning sticker on steering wheel "do not start - no oil". Onc eyou decide to take the car out of storage, put fresh oil in and motor on.
As for gasoline, I'd use nothing but 98 octane gas WITHOUT ETHANOL for storage. Fuel with ethanol will cause harm to your fuel system components which will be much higher that hypothetical damage from starting the engine and letting it run for 20 seconds.
Doubt that. There have been guys here with vehicles that don't drive them much each year (like 750 miles or less per year), and have gone 3-4 years between oil changes. Sent in a sample and the UOA comes back fine. It's most important to get the oil nice and hot when it's driven. Lots of short trips or short run cycles without getting the oil to full operating temperature will cause lots of cumbustion condensation and fuel contamination. You don't want oil like that staying in the engine long term.
It's not rare to see some additive fallout on a used oil container. I checked date of manufacture and they all were bottled within 1-2 years. Yet some additive fallout occurs (especially on cheaper oils). I think oil needs some circulation to prevent that. So even low mileage as 750 miles per 4 years helps this versus 2 years of just sitting still in the oil pan. That's one thing.
Another thing, I'm a bit sceptical about all those VOAs/UOAs being able to reveal 'the truth' about oil's life, composition and performance. Of course, some aspects are inargueable but... Let's UOA shows just Zinc and Phosporus. In report they are shown as 2 elements (Zn, P) but in reality it's complex long-chained molecules. Can you (or the lab) guarantee that those Zn/P molecules are the same length/composition as they are intended to be? I don't think so. But... Even if the oil has been sitting, has oxidised, Zinc and Phosphorus won't evaporate from it, thus it still appears in lab report. I think you get my idea.
Fuel, condensation and oil life degradation due to short tripping/frequent engine (re)starts. Well, my daily trip is 6 km one way. Sometimes even shorter if I need to drive to a shop which is less than 1 km away. Me and hundreds of thousands of other people don't think and actually don't care about that. They just need the car serve to them, not them serving the car.
My TDI has been short-tripped it's entire life (12 years of my ownership). Engine is still good, no turbo shaft play, no noticeable oil consumption. However, the car is almost done due to body rust. I wouldn't overthing about that moisture/fuel dillution too much.
By good do you mean usable or good as in not harmful to the engine? I've had gas cans with Stabil and years old gas (like 3 years old) that I use in lawn equipment and they run with it. It's probably not good for them but they run fine. It's also 10% ethanol gas in a high humidity climate.
Changed the oil on this 2012 S500 earlier this week. The car had been sitting for 60 days. I didn't start the vehicle as part of the oil change, cold oil removed with an extractor. The extractor has good measuring, so I was able to validate the quantity of oil removed.
The car will likely sit for the next 24 months. The fuel tank is full with a proper stable mix in the fuel. I am not wanting to start the engine as to reduce the fuel level, even if insignificant.
Oil is at the proper level, and the dip stick validates the oil level in the pan.
Any reason I should circulate the newly installed oil?
View attachment 248165View attachment 248166
I would *absolutely* start it, drive it once and fully up to operating temperature, and then store it. If you don't, you're leaving all the old, potentially acid-contaminated oil trapped in the bearing spaces and giving them months of time to etch. That's less of an issue now with low-sulfur fuels and especially if you always get the oil hot before shutting off, but acids still form in oil. Fresh oil in the bearing clearance spaces sure doesn't *hurt* anything, and even if you burn 2 gallons of fuel off, so what? That's very little proportional added air space trapped over the fuel... and you also pull your stabilized fuel through the entire system. One other thing... if you store it without running it after an oil change, You're leaving an air space in the filter and pickup tube that gives space for oil to drain back more out of the galleys, and will further delay full oil pressure when you DO re-start.
Honestly, I don't think you'll measurably change the life of the engine one way or the other... but we are all about splitting fine hairs on here. :p
And how often do you change the oil? Short trips in about every OM equates to the severe service maintenance schedule, which means relatively short OCIs.
When I had a full time job + other activities I was changing it every 15'000 km and it accumulated that mileage in 10-11 months.
However, now I don't have a full time job and much less activities which require a car so I change the oil every 1.5 years. Mileage on oil is low (less than 8'000 km usually; average car speed is 36 km/h per OCI).
Car has 190k km on the clock now.
