Any reason to run an engine after a oil change?
GON
$175 Site Donor 2026
White Sands, NM
Changed the oil on this 2012 S500 earlier this week. The car had been sitting for 60 days. I didn't start the vehicle as part of the oil change, cold oil removed with an extractor. The extractor has good measuring, so I was able to validate the quantity of oil removed.
The car will likely sit for the next 24 months. The fuel tank is full with a proper stable mix in the fuel. I am not wanting to start the engine as to reduce the fuel level, even if insignificant.
Oil is at the proper level, and the dip stick validates the oil level in the pan.
Any reason I should circulate the newly installed oil?
I would run it for 30 seconds to ensure: (a) the oil was fully circulated and the level was still at the full mark after filling the new oil filter (if it was changed); and (b) to circulate some of the stabilized fuel into the fuel pump/rail and injectors. The amount of gas pulled out of the tank will be insignificant. I would be more focused on filling the tank with non-ethanol gas than having an extra 50 ml of air space in the gas tank. If the S500 is stored inside your garage, 24 months won't be an issue for the fuel. If it will not be driven while you are overseas, I would suggest disconnecting the negative terminal on the battery and connecting a maintenance charger every ~90 days for 48 hours to keep the battery topped off. Also, overinflate the tires (including the spare) by 5 psi over the value you normally run.
Condensation build-up from running it for only 30 seconds (i.e., engine won't be warmed up) will be inconsequential since this is a one time situation, not an ongoing/chronic/daily occurrence.
I wouldn't bother starting it for 30 seconds or whatever. Why? Because there's still residual oil on the cam lobes and such from the oil that you removed. There's still a film clinging to the surfaces. And when you start the car to circulate the new oil, after you shut it down, most of the oil drips back into the pan again anyway, and once again you're left with a film.
Also, it isn't good to start an engine and shut it off quickly. You're just going to introduce moisture into the oil that won't be cooked off because the engine won't get hot enough. Just leave everything as it is, imo.
There are preservative engine oils for long term storage. Mil-L-21260 Rev. d oils meet this requirement. They function as an engine oil but have enhanced rust protection.
If you don't go with a storage oil, I would use a mineral oil-based oil with a high TBN. Mineral oils will be the most stable during storage. Ester-based oils or oils using esters for solubility may be something to avoid. Esters may breakdown in damp or wet environments.
Engine oil's high TBN is usually achieved by using metallic sulfonates which also serve as rust inhibitors.
I would run the engine to operating temperature to be sure all components are coated with the fresh oil.
View attachment 248165View attachment 248166
The oil pickup could have drained, so you could lose prime on the oil pump. It depends on the design of the oil pan, pick-up and height of the oil pump though.
But whether he starts the car now or starts it in two years, it will reprime the pump if it did lose it's prime from the change. Doesn't matter if it starts it right now or not.
no if the oil pump gets enough air in it, it might not prime for a long time cranking. it depends how much ckearance there is. Similar to what happens on a new build.
I wonder just how much moisture, if any, would actually be created if you only run an engine for 15-30 seconds. I’m guessing it is probably next to nothing. I think once you get past the one minute mark and a little bit of heat starts building, then that’s when the moisture comes into play.
