Well, I've keep it the last 6 years.Are you keeping this car?
Putting a first Gen Honda Insight back on the road that's been sitting 6 years and will be doing two oil changes a few hundred miles apart to clean the engine internally. Any reason I shouldn't use Mobil 1 5W30 that I got during the Walmart clearance for 10 cents a quart for the first change before using the correct 0W20 on the next one?
Maybe not so much cleaning as getting out all the 6 year old oil. Like a spill and fill on a transmission.Neither is going to do any cleaning, so if that's the goal here, you may want to use an actual cleaning product or at least an oil that claims to actually clean like Mobil 1 0w-40. @High Performance Lubricants makes an ester-based dedicated engine cleaner oil that could be mixed with your 5w30 to provide some actual cleaning power.
So true.Yes but you seem to have dozens of cars.
"and will be doing two oil changes a few hundred miles apart to clean the engine internally"Maybe not so much cleaning as getting out all the 6 year old oil. Like a spill and fill on a transmission.
Which is a tad bit different than two oil changes over a few hundred miles as the OP stated.If you belive Mobil's photos the Accord top end sure looked cleaner after 100,000+ mi of Mobil 1 Extended Performance at 15,000 mi OCi.
Well he did say, "Neither is going to do any cleaning...".Which is a tad bit different than two oil changes over a few hundred miles as the OP stated.
LOL! OK, any noticeable cleaning. Oils aren't designed to clean, they are designed to keep things clean, and you'll notice that their marketing literature is crafted to convey that point, but it's very easy for the consumer to infer that the product cleans. There are few instances where the manufacturer will state that the product can actually clean, in the cases that I'm aware of, that company has been Mobil.Well he did say, "Neither is going to do any cleaning...".
I never forget the saying about what we do to ourselves when we assUme.LOL! OK, any noticeable cleaning. Oils aren't designed to clean, they are designed to keep things clean, and you'll notice that their marketing literature is crafted to convey that point, but it's very easy for the consumer to infer that the product cleans. There are few instances where the manufacturer will state that the product can actually clean, in the cases that I'm aware of, that company has been Mobil.
