Any good oil thickener
He wants it for a semi truck. Think north of 15w40. The OP could go 15W-50. Something like HPL 15W-50 would fit the bill nicely, as it cleans, and has very good anti wear properties. Of course, it's expensive, but you get what you pay for.
exactly you do get what you pay for! I have to shop around when I buy motor oil in transmission fluid and I always try to buy at least a case. for all of you out there considering a boutique product sometimes even if they don't have it on their website they will work with you and catch you or break sometimes over the phone. I try to keep enough on hand to help offset the rising costs due to many variables out of my control and still not have so much that I have to look to giving it away so that I don't not use it in time. I kind of always wanted one of those paint shakers where they put the colorant in a bucket and then it agitates and spins for a minute or so. that'd be fun to do with some l o s and see all the bubbles. I still like to play with the hand crank display at the parts store.
If you believe that a single product with a viscosity of 45 Cst at 100C can simultaneously “increase viscosity” and “provide easier cranking” in cold weather, then Lucas is the product for you.
https://www.lucasoil.com/pdf/TDS_Pure-Synthetic-Oil-Stabilizer.pdf
If you believe that a product made of group 1 oil “increases lubricity” and “extends oil life”, then Lucas is the product for you.
https://www.lucasoil.com/pdf/TDS_HD-Oil-Stabilizer.pdf
now on to an honest question? wouldn't there be some high-dollar oils that are thicker because of their build? and guess what I'm saying is there's a little bit of give and take and a certain way of oil has to be so thick but there's a parameter where it can be on the thinner side. I kind of thought I was getting that from the zero w20 Redline oil as it's thicker than just about any other 20 weight but it's chemical makeup and composition allow for it to perform better at Colder temperatures.
How much do I need to add to a 12 gallon oil change?
here we go....
12 qts of 20W50 should be thick enough, if not add some cheap off the shelf " motor honey" to the mix, or STP blue bottle. All of those additives are fairly cheap. 700k is not terribly high mileage. Semi engines go longer if properly maintained. Got a feelin something else is brewing in that engine. What I don't know. Maybe have a good diesel mechanic look at it. Might be something he seen before.
You can but that Lucas at any truck stop by the gallon jug.
Thats thick stuff and my guess some truckers must use it for a reason?
There are a lot of things for sale at truck stops that are designed to separate a fool from their money.
Most of them sell quite well.
Good sales in that venue, with that intent, should not be construed as a measure of quality.
Lucas Oil Stabilizer is a low cost and low quality viscosity improver, sold at huge markup. When you replace 10% to 20% or more of your motor oil with Lucas, you have that much less anti wear additives, less detergents and dispsants, and so on. Just cutting down ZDDP, friction reducers, and detergents & dispersants, is good enough to effectively destroy the bearings inside a turbo in a diesel engine. After that, the piston rings will wear out, because Lucas is a magnet for dirt, and also likes to create deposits. The rings will have so much wear that when remove them, you can use them for shawing. The rod and main bearings in a big Diesel engine will go last, because these bearings are so big. You probably will have to rebuild your engine before they let go, because of the increased blowby and decreased power, and probably because you're tired of replacing turbos because... you keep using Lucas. Some folks never learn.
In a personal vehicle with a gas engine Lucas will do some serious damage. It prevents oil from getting where it needs to be, fast enough, by clogging up passage ways that are narrow, like those inside an oil-coolant heat exchanger for example. That's why Lucas came out with a thinner version of their crud and dubbed it "Synthetic", whatever that means ... for what it really is.
But hey, if you, or anyone else wants to use Lucas, or keep using it, by all means. It's not my problem, and I won't suffer the consequences of such a bad decision, you will.
You know that is very good , sound advice you explained to the OP, that needed to be said.
All of those products , do "something" but the questions as you pointed out is what happens when used and used for what purposes.
The very first thing I would do , and I got a good feeling many will think the same. Why not just bump up to the same oil in use if there is a thicker viscosity available before even thinking of some product other than motor oil? I never add a thing to the motor oils I use. I have the feeling if I select an oil, an oil I have researched a good bit about first, why should one need to add anything to their motor oils?
