Schaffer's #132 will thicken oil, it was respected here too. IIRC it comes in gallons.
Would that be a better choice mixed in with Rotella or Delvac than Mystik 15w50?Schaffer's #132 will thicken oil, it was respected here too. IIRC it comes in gallons.
Honestly I don't know, I'd call l and ask them on Monday, and get an answer right from the source.Would that be a better choice mixed in with Rotella or Delvac than Mystik 15w50?
What's your goal?Would that be a better choice mixed in with Rotella or Delvac than Mystik 15w50?
Still waiting for proof.Lucas Oil Stabilizer is a low cost and low quality viscosity improver, sold at huge markup. When you replace 10% to 20% or more of your motor oil with Lucas, you have that much less anti wear additives, less detergents and dispsants, and so on. Just cutting down ZDDP, friction reducers, and detergents & dispersants, is good enough to effectively destroy the bearings inside a turbo in a diesel engine. After that, the piston rings will wear out, because Lucas is a magnet for dirt, and also likes to create deposits. The rings will have so much wear that when remove them, you can use them for shawing. The rod and main bearings in a big Diesel engine will go last, because these bearings are so big. You probably will have to rebuild your engine before they let go, because of the increased blowby and decreased power, and probably because you're tired of replacing turbos because... you keep using Lucas. Some folks never learn.
In a personal vehicle with a gas engine Lucas will do some serious damage. It prevents oil from getting where it needs to be, fast enough, by clogging up passage ways that are narrow, like those inside an oil-coolant heat exchanger for example. That's why Lucas came out with a thinner version of their crud and dubbed it "Synthetic", whatever that means ... for what it really is.
But hey, if you, or anyone else wants to use Lucas, or keep using it, by all means. It's not my problem, and I won't suffer the consequences of such a bad decision, you will.
Would STP be considered a thickener?
Cummins ISX15 - Wasn't that the motor that Valvoline created the Premium Blue Restore for with warranty issues?@Redland1 you have asked similar questions in other threads before.
https://bobistheoilguy.com/forums/threads/is-mystik-jt8-15w50-a-good-oil-for-a-semi-truck.376916/
I can appreciate oil and additives are cheaper than a rebuild, but that said oil and additives only delays the inevitable. You might want to consider addressing the root cause of your problem if at all possible.
Just my $0.02
Not really as gear oils and motor oils are graded on different scales.75W-90 will fix her up!
Increase oil pressure and consumption.Oil pressure is still within spec but I went it on the higher side of the specs.What's your goal?
Really?Increase oil pressure and consumption.
Oil pressure is nothing more than resistance to flow. And you want good oil flow, trust me.Oil pressure is still within spec but I went it on the higher side of the specs.
Isn’t that life….Fixing a problem he doesn't have...
2004 ISX15 cm870.530HP,and about 700k miles.Really?
What engine is it (all the details, including year), and how many miles on it?
Original miles, or since it was rebuilt the last time?2004 ISX15 cm870.530HP,and about 700k miles.
