Is Mystik JT8 15w50 a good oil for a semi truck?
San Antonio Texas
Hi.Looking to switch to the Mystik 15w50 because my 03’ Cummins ISX15 is getting up there in miles and I want a heavier oil to keep the oil pressure up and consumption down as it wears.Is that oil a good choice?
mystik is made by citgo,, long time ago i used the 10w-30 and the 5w-30 mystik dimension semi-synthetic,,,was a decent oil
a decent oil for a good price, many motor cycle owners like. in my lo mile 50+ thou loose audi TT tuned 1.8T i see higher vacuum + less consumption with Redlines 15-50 real synthetic, but only 4.25 qts so cost is not bad!!
currently running the 15w40 JT8 in my 2012 Ram Cummins. First fill and no signs of issues. It will be a while before I UOA with winter upon us, but my first impression is this is a good oil and is reasonably priced IMO.
Just my $0.02
Not sure where the OP is buying it, but I bet a 5 gallon pail of JT-8 isn’t a lot more than 5 quarts of Red Line!
Which, of course, you meant citgo.
ugh ... yes ... 😖
I have used JT-8 extensively in my 2014 Road King for 8ish years. Many UOAs in here, oil temps in the bike would run as high as upper 660s stuck in traffic a few times. Last oil change, for fun switched to Mobil 1 15/50
It's a rumor I could never confirm that Harley oil is produced by City. True or not I don't know but the only place I could ever buy a HEDO 15/50 which the HD oil is said to be formulated like, no documentation, except HD call for diesel oil if their 20/50 oil is not available. With the disclaimer to change back once it is (of course ha ha)
The Mystik 15w50 is designed for older agricultural equipment. By older, I mean pre-Tier equipment, so from the 1940’s to the 1990’s.
Will it work in a 2003 ISX? Yes. Would I personally recommend it? Not really. If you’re losing a lot of oil pressure, you’re going to have something mechanical going on. I would start with that instead of throwing a (fairly) expensive oil at the problem.
But to answer the question, it’s a good oil. Certainly has a niche in the market place.
My fleet still has a few 1980’s to 2007 engines out there. (Mostly CATs) and we run all 15w40’s in them.
I run it in my 2019 Pete, I have 160k on it so far and it’s been doing great! This is a Glider Kit with a C15.
