My gas furnace is giving me some fits right now. I called some folks I've used before to come check it out, and their technician pronounced it "dying" and quoted me a new furnace. He did give it a cleaning and found that the gas pressure was high, so he readjusted the gas pressure. He noted there was a small crack in the sheet metal near where the pilot jet goes (not in the heat exchanger), and he reasoned that the higher gas pressure was making the pilot flame a little too big, which torched the sheet metal and cracked it. FYI, the furnace is about 14 years old.
Here's what it's doing. It seems to be overheating. It will start normally, but the burners cycle on and off frequently while the thermostat is still commanding heat. It never did that before. Sometimes the thermostat will command heat, but the burners don't start at all until several minutes after it commands heat. Other times, it will shut down normally, but a few seconds after it shuts down the blower motor comes on again. When I did some troubleshooting, one of the rollout switches seemed to be opened, but the technician said they are not self-resetting. He was thinking the big pilot flame was getting too close to the rollout switch and tripped it, but I never had to reset the switch.
The filters are clean, but it sure seems to keep a lot of heat inside it. Maybe getting a second opinion would help, but I'm trying to figure out whether the heat exchanger is worn out, dirty, or cracked and that's why he's recommending a new furnace, or if it's just "old" and he wants to sell me a new one.
