Any filters equivalent in size to ph4386?
I used to use this for my 09 camry and it worked fine for my purposes. It was nice bc it was sort of long. Inexpensive as well. Then it seems they got rid of it and anything else the same length (super tech, fram, etc) at walmart and elsewhere. Makes changing the oil so hard for me since i have to reach in to that tiny space and try to rotate it out. Any ideas where to get it or something of the same length for like $10 or less? Thanks a ton!
The carquest 84145 is the best. But I know lowes sells the 4386 so check if your local one has it in stock. What are your intervals. If you change frequently the shorter one will be just fine. The ST4967 is cheap but has metal caps but a nitrile gasket instead of preferred silicone.
The toyota oil filter 90915-YZZF1 will fit and is 3 1/2" long. My walmart and toyota dealer stock these. Those 4967 length filters are to short to deal with in my 2009 Toyota 2.4.
