Originally Posted By: Jim Allen
Has anyone seen any oil pressure comparisons for oils of a similar kinetic viscosity but differing HTHS?
That would be a neat test, but probably hard to replicate exacting conditions for all of the runs.
Just out of curiosity, I looked up the oil pressure specs for my Altima in the service manual. It accepts 30 or 40 grade oils as per the manual, and lists the following blanket specs:
Hot engine, hot oil:
Idle: >14 psi
2000 RPM: 48 psi
The bypass valve opens between 70-75 psi, and with a minimum of 50 psi at 2,000 RPM, it's very hard to believe that my oil pump won't be in relief mode well before redline (which is 6700 rpm). Given this info, I should be bypassing by about 4,000-4,500 rpm on hot oil as per the recommended grade.
It seems to me that most commuter cars are designed this way. Perhaps the extra flow attained by using a thinner oil (thus increasing the RPM at which bypass occurs) is not necessary. I'm sure manufacturers would test to make sure flow rates under all operating conditions are adequate.
Talking about all this stuff makes me think of one of my buddies who lives 35 min north of me. In the winter time, it's not uncommon for it to be -30C or lower at his place. His cars sit outside all night. He does use 0W30 oil in all except for his Benz (5W40), but when he starts them up in the morning, his foot is planted and he's redlining them cold or hot. No concern for the engines. All of his vehicles have very high mileage on them and seem to run just fine. Obviously, oil flow is terrible at those super low temperatures, and the pump is probably bypassing at idle speed let alone driving. But still his engines live on. He has 450,000 km on his 2002 Grand Prix GTP, 360,000 km on his GM 4.3L V6 (Safari), 280,000 km on his 98 Mercedes S500, and 350,000 km on his 93 Taurus SHO. His long gone 3.5L Intrepid was on conventional 5W30 it's whole life and lived to see 600,000 km before he scraped it for the GTP. Yes he drives a lot.
We must be splitting hairs here with thin/thick oil discussions!
Idle: >14 psi
2000 RPM: 48 psi
