Slick, I think you have unwittingly "stepped in it" ...
So I offer a joking and somewhat pointed retort to your quest, in jest.
So, by posting a question yourself, you'll be able to find it? But if someone else posted the same question (about a thousand times by now at a bare minimum), you can't seem to find it?
So the search button in the upper right hand corner is elusive?
The only consensus is that there's no consensus.
There is no cardboard. Some of their products have resin reinforced fiber caps. It's been that way for a long time. And, despite the implied heresy, we've not seen these "cardboard" endcaps come flying off and being ingested by the engines.
Too late ...
You're welcome after the fact.
Well I didn't, so apparently your conception powers could stand a tune-up, Bob.Here's 10 pages of threads with "Fram" in the thread title .... using the search function (see image with blue arrow).
Use the advanced search, type the keyword(s), select the sub-forum (filters) and
VIOLA !!!
https://bobistheoilguy.com/forums/s...]=1&c[nodes][0]=6&c[title_only]=1&o=relevance
It is inconceivable that you can't find what you want to know (and a whole lot more) in these pages.
But none of them are owned by BITOG members.Millions and millions of cars are motoring on with the cheapest possible jobber oil filters and bulk oil in them and they don't appear to be suffering.
Hello all,
Couldn't really find an answer here (and wasn't quite sure how to search any further than I did), but has anyone here ever noticed anything resembling a consensus on Fram filter design quality, please? I recall reading (about 15 years ago) quite a bit on another Forum (Pick-up trucks), Fram's being built with a cardboard internal part, and many there didn't like that at all (and it sure didn't sound at all appealing to me either).
Not looking to start any fights/arguments here.
THX in advance....
The underlying message I get is you're a hardcore FRAM fan.If you don't like fiber end caps (not actual "cardboard" like some misinformed refer to), and are interested in Fram then get the Ultra, Titanium or Endurance. The ones with fiber end caps work fine for what they are designed for.
LoL ... it's called facts. There is no proof that non-metal end caps don't work, or are "bad". If they are "bad", what makes them bad if they work as intended? Where is the poof they are "bad", expect from people who say they are just parroting with no actual proof they are bad?If I read in between the lines, I'd say you're a hardcore FRAM fan.![]()
The only thing holding that filter up is its metal center core. It's like the "pole barn" principle.LoL ... it's called facts. There is no proof that non-metal end caps don't work, or are "bad". If they are "bad", what makes them bad if they work as intended? Where is the poof they are "bad", expect from people who say they are just parroting with no actual proof they are bad?
All oil filters have some kind of center tube, regardless of what kind of end caps are used. It's not the end caps job to "hold up" the filter. The function of the end caps is to provide a sealing surface for the pleat ends and the area around the center tube on the end caps.The only thing holding that filter up is its metal center core. It's like the "pole barn" principle.![]()
Structural integrity. I learned that term from aircraft mechanics school. It's another way of saying, "makes it stronger."What do you think the real purpose of a center tube is?
Structural integrity of what? Makes what stronger? Yes, this is a quiz.Structural integrity. I learned that term from aircraft mechanics school. It's another way of saying, "makes it stronger."![]()
The oil would still flow from the outside the the inside of the filter element even if there was no center tube. So another misconception, lol.The other purpose is to provide a pathway for the oil to flow from the outside of the filter element to the inside of the filter element.![]()
An oil filter is like a spool used to hold electrical wire. The only difference is there's a filter between the hollow core and the outer flanges.Structural integrity of what? Makes what stronger? Yes, this is a quiz.![]()
If you've looked closely at some filters with floating center tubes, and some of the Fram filters with fiber end caps, the center tubes are not always as long as the distance between the end caps. Which means they aren't really fully acting to "prop up" the element. With all the pleats in compression, that proves a lot of resistance from the element compressing. The main purpose of the center tube is not to "prop up" the element assemble, but yes the center tubes can certainly help take some compressive forces off the pleats. A center tube's main purpose is to give the media some structural integrity so the media doesn't get blown out from the delta-p created by the oil flowing through it, and sending into the oiling system.An oil filter is like a spool used to hold electrical wire. The only difference is there's a filter between the hollow core and the outer flanges.![]()
Lots of people on YouTube are just parrots repeating something they've heard, and have no real understanding of oil filters.Just to add to the discussion, very insightful video despite the hate comments on youtube.
