hey guys.
i see lots of talk from users who are looking for over sized oil filters to fit their applications etc...
what exactly are the benefits in running a larger filter? is it just more filtration?
what negative effects does running a larger than recommended oil filter? reduced oil pressure or flow?
currently my Honda uses a fram ph3895 oil filter. fram makes a filter that is MUCH larger the ph3985 with the same threads and gasket mating surface. (I'm only using fram as a reference since they are easy to find around here. i can cross reference the filters to other brands)
its about 25-35% larger in physical size. so it should have that much more filtration?
