You know, I think we're on the same page. So you think this engine used inferior oil?
It's possible because we have no idea of either the brand or the viscosity of the oil that was used in that engine. But it depends what you mean by, "inferior oil"? According to the video, the owner depended on 2 Toyota dealers for service.
That said, do Toyota dealers use, "inferior oil"? Because according to the mechanic, that car never saw a Jiffy Lube... Only Toyota dealerships, and 10,000 mile oil changes.
We know for certain that 2 of the cylinders had clogged piston oil cooling jets, (or whatever they're called), that were not functioning. And we also know
it was the same 2 cylinders that had the gunked up, frozen oil rings that deeply scored the cylinder walls enough to trash the block.
So the question then becomes, what caused them to clog? We can tell by the size of the cooling jet orifice, that while possible, it's pretty unlikely it was a single piece of debris that clogged it. Let alone 2 pieces that clogged both of them.
So that leaves buildup of gunk, sludge, crap over time inside the orifice itself. The time factor is there, because he went with 10,000 mile oil and filter changes. Add in "inferior oil", and that would certainly help speed the destruction process along.
So everything points to oil. Either oil that was not changed often enough. Or poor quality oil. Or all of the above.
The important fact to remember, is it was only the 2 cylinders that weren't getting proper cooling oil on the pistons that had the frozen rings, along with the scored cylinder walls that caused all of this... Nothing else.
So if those 2 oil cooling jets had not clogged,
none of this would have happened. Because there was nothing else wrong. The scored cylinder walls were caused by the frozen up oil rings. And the rings froze up because the pistons that held them
OVERHEATED.
And it was that combination that led to the high oil consumption, and the $6,000.00+ bill to fix it.
