Doug,
All your oil samples show abnormal levels of nitration and oxidation - this is what is causing the high solids level and making the oil thicken in a very short period. Elevated nitration/oxidation are due to an engine that is not functioning the way it should and are NOT an oil problem. I suspect you will see this same thickening occur regardless of what oil you use, in fact I'm very sure of it.
Accelerated nitration is typically caused by an engine with low combustion efficiency, due to plugs in poor condition bad engine timing, etc. It can also be caused by elevated cylinder head temps - ie the Toyota V-6 problem. The other thing is to make sure the EGR valve is operating normally and isn't staying partially open all the time and dumping "NOx" laden exhaust gases back into the engine. Accelerated oxidation is also caused by elevated engine temps, only it occurs in the presence of oxygen, which reacts with the oil to form insoluble polymers....
I've run this same oil for much longer periods of time and never seen this thickening problem. As just one example, I ran some of the Amsoil 0w-30 for 16,000 miles and 1 year in a 97 Vw Jetta - in a very hot climate - and the viscosity was about 12.5 centistokes; up from 11.3. The kind of thickening you are seeing should not occur for 15k to 20k miles in a mechanically sound engine.
I suggest running some Mobil 1 for 5000-6000 miles and testing it - I suspect it will thicken from 10 Cst up to 12-13 Cst in that short a period of time.
Please let me know if I can be of further assistance ....
TS
TS
