Amsoil Selection
Originally Posted By: Pablo
That's the true beauty of synthetic oil. 15W synthetic won't be a problem in all but the coldest mornings.
Some people aren't convinced and think 0W is the way to go. I currently run Castrol Syntec 20W-50 and heard good things about it. Any info on it and comparison to Amsoil?
This is the oil I am referring to: http://www.castrol.com/castrol/genericarticle.do?categoryId=82915470&contentId=7032644
I run 0w30 in my turbocharged car...but I don't wail on it constantly at all either. For every 100 miles I drive I might be in boost 1-5 of those.
But if I were driving a little bit older vehicle hard, and a boosted car at that, I doubt I'd consider a 0w at all. Newer cars are designed and specified for it. Older cars with some miles on them aren't exactly the prime market for these oils though.
My $.02, anyway.
You can easily see the specifications on the RD50. Castrol might take some digging. I can say with certainty the RD50 15W-50 will flow much better than the 20W-50.
Here, I found it. Not really sure how to interpret it though
http://www.castrol.com/liveassets/bp_internet/castrol/castrol_usa/STAGING/local_assets/downloads/p,q/pds_syntec_usa.pdf
Your oil viscosity choice should be made based on what sort of oil pressure and maximum oil temps you're seeing in your car.
All the discussion so far is just plain guessing.
If you don't have these gauges I'd recommend you install them.
The RD50 is thinner at -20C° than the Syntec is at -15C°.
So it'll flow much better at cold starts? I'm mainly worried about the RD50 because ive heard it's not good for a street car due to it's additives
Yes. Better cold.
Which additives? Please detail what you heard. And from whom. Thanks.
Yes. Better cold.
Idk, I read some stuff in this thread after looking up the Dominator series. Although I dont have a Subaru, it still made me a little concerned
http://forums.nasioc.com/forums/showthread.php?t=1690019
I didn't see too much worthwhile, factual info there, other than the info they posted from the respective companies' websites.
As they admittedly point out, Dominator clearly mentions it is acceptable for street use. If it were not able to be run on the street, I would be expect Amsoil to notify that strongly in the product description.
Stout oil, made or a race-oriented motor that gets driven hard quite often. Not designed with a high TBN and extended interval particulars, but that isn't what you're going for, so you're just fine.
By the way, it probably still has quite a bit higher TBN than the majority of shelf oils, if I had to go out on a limb.
So say RD50 is THE best amsoil, which would be second best?
Well, there isn't necessarily a "best" oil in Amsoil's line, unless you break it down by use. Pablo is helping decided what is a great choice for you more than anything. It doesn't mean the others won't do what you're asking it to.
I consider SSO the best...but that's because it meets my spec AND meets my goal of extended drain intervals, mainly.
Like to know what you did not like about GC. People still need more info to make a correct pick to start with for your app.
Second best at what??
Some good questions remain unanswered, but the AMO 10W-40 or the HDD 5w30 are good choices as well.
