YesYes, that was my understanding, and, as @buster noted, I thought it was SWRI?
Thank you for confirming!
How would anyone know the answer to that question?Playing devils advocate:
How many oils out there only strictly meet the industry minimum standard?
Those that use only boutique oils will tell you that API oils are bare minimum watered-down garbage. We know that's not true. The off the shelf synthetics, especially the top tier within the line, greatly exceed the IVA, IIIH, V, TEOST, and GM Turbo tests.Playing devils advocate:
I look at it as Amsoil comparing their oil against tough industry standard tests. They doubled the length of the IIIH and showed the results and they showed how far below the 90micron max limit their 0w20 was on the IVA. A lot of oils do well on these tests.That’s my point. And my point with most oil advertising.
They say it’s “20 times cleaner” or something made up like that. But… against what?
Not saying amsoil makes a bad product in my statement. I’m just more so hitting on marketing.
Amsoil is effectively comparing it to nothing with these tests. All major oil companies are guilty of the same thing. Shell, P66, Chevron, Mobil, etc.
They do some test. Then compare it to “industry standard” - which is a pass/fail test.
If they wanted to make marketing, they would compare it against named products.
Proof that p66 does the same thing:
Now I won’t get into the purse swinging. But I have this same slide with names named, too. Just this marketing annoys me. Because it’s not actually showing anything besides how amsoil does agains the pass/fail standard.
I’d basically like to see more put up or shut up testing.
Exactly my point. As you and I have discussed, if you’re using a top tier synthetic. The differences between Mobil v Kendall v SOPUS v Valvoline or whatever, full synthetic, are minor enough that especially a “normal” user will never tell the difference. Your engine life will be statistically the same.Those that use only boutique oils will tell you that API oils are bare minimum watered-down garbage. We know that's not true. The off the shelf synthetics, especially the top tier within the line, greatly exceed the IVA, IIIH, V, TEOST, and GM Turbo tests.
Between marketing, legal, formulation and additive supplier/blender relationship on what they're trying to target etc.... The IVA in particular has been used over and over again to prove wear performance.
Hhahahahaa that's funny and TRUEI’m simply bitching about marketing… because… This is the internet. And it’s what you do, on the internet.
I agree, and on the flip side...let’s say you have an engine with a design flaw (maybe oil consumption/fuel dilution/bearing clearance/oil pressure issues), are any oils going to combat that and do better than the other? Maybe, but probably not. Either way, oil is going to do so much. Change it, take care of your car, try not to buy one with known issues.Exactly my point. As you and I have discussed, if you’re using a top tier synthetic. The differences between Mobil v Kendall v SOPUS v Valvoline or whatever, full synthetic, are minor enough that especially a “normal” user will never tell the difference. Your engine life will be statistically the same.
I just look at it as “safe” marketing. They can show something, anything, that they can claim some big number. But they’re not actually testing it against their competitors. Especially a test that uses a 1980’s engine for. And the test was developed 20 years ago or more.
But to me, this is like… I guess going to a movie and seeing everything wrong about the movie because you did the xyz thing.
I’m strictly playing devils advocate here. And I am absolutely not saying amsoil makes a bad product.
Mobil has done some interesting comparatives in the past, like these slides:That’s my point. And my point with most oil advertising.
Think it was a European-centric presentation, yeah.My Driver in the EU had over 700k miles on his car with M1 New Life - guessing that came from the UK ?
This one clearly has modified lighting, but still shows a relevant sequence (IIIG):
The random labels you never heard of sold in the USA, which PQIA testsPlaying devils advocate:
The spinning disc doesn't replicate the piston movement on an engine. It's as good as a Project Farm test.Mobil has done some interesting comparatives in the past, like these slides:
