Hi,
the topic of oil and engine temperature is a complex one
In support of the argument that the temperature gauge is unlikely to "tell the story" it is worth considering the following.
Case1 - I operate a MY02 Subaru Outback as my "Company Car"
It has covered 90kkms and the coolant temperature gauge has never
varied at operating temperature - ever
It has had four types of oil in it;
a) factory fill ( about 2kkms )
b) M1 0w-40
c) M1 10w-30
d) D1 5w-40 ( 24kkms )
( oils b, c, d were changed at around 12kkm intervals )
It has operated in temperatures from -6C to 45C
Last week I covered 1200 kms in one non stop trip in an ambient ranging from 5C to 36C in our tropical spring. There was a very strong following wind for about 600 kms - the gauge never varied.
Speeds were around 160km/h for some hours ( don't tell Mr Plod!! ).
This car like most new Asian and Euro cars has a "sanitised" temp
gauge - one that constantly sits at normal on a small band of say 3C to 5C
- a factor of the "sweet position" of the sensor on the engine
and the way the gauge is designed to operate.
They are designed as a "package" to indicate when something is wrong - outside a given band and to quickly indicate when an over-temp occurs!
Usually, once the coolant is at the thermostat's "crack" point the gauge will move down a little and then remain there. Unless of course other operational aspects
cause the engine to gain temperature.
It will NOT get cooler unless the engine stops of course - the thermostat sees to that
This means then the gauge is always displaying the best result from the operation of the engine's thermostat, the device that
regulates engine temperature, and displaying a sanitised reading
The can be no influence of a "parasitic" temperature change from another oil shown here
Case 2 - Until recently I owned a MBG with a factory fitted non thermostatically controlled oil cooler fitted in the main oil gallery. The cooler was aluminium, the hoses over a metre long and it was mounted in the full air flow in front of the radiator
On a -5C day the "non sanitised" gauge would reach a little above thermostat crack
point ( 78C ) then go down a little and stay there. The oil cooler lines would be about 40C in and about 30C out. No real effect of the extra cold oil was shown on the gauge
On a 40C day the engine would reach slightly above normal and the oil cooler lines
would be near 90C
Again, no real effect on the gauge reading was noted due to the oil's temperature
Case 3 - My Porsche V8 ( alloy block and heads ) has a large capacity and very complex cooling system. The thermostat which is mounted on the bottom hose entry to the water pump opens at 83C and is fully open at 98C. The radiator is a "heat sink" - common on some German cars. Part of the cooling system is a large capacity oil pan and a thermostatically controlled oil/coolant heat exchanger embedded in the radiator. The oil system thermostat opens at 87C and is fully open at 95C.
The complete system is so complex that in nearly 40 readings taken over some months and involving nine key points I could not have detected a meaningful variance in oil temperature due to "parasitic" friction reduction or heat dissipation via the oil
The non sanitised gauge in this car is constantly moving due to the nature of the sensors and coolant flow path. A good reason why the gauges are now sanitised perhaps?
To get an accurate temperature "picture" on any vehicle's engine a lot of careful monitoring and data acquisition and analysis must take place
Regards
b) M1 0w-40
c) M1 10w-30
would be near 90C
Regards
