Originally Posted By: GM4LIFE
I was going to go with Amsoil Signature Series, but was worried about the Dexos approval rating, so I just went with standard Mobil 1.
If I were you, I would run the Amsoil EAO oil filter and Mobil 1 Advanced Fuel Economy 0w20 or Mobil 1 Extended Performance 0w20. You will be MORE than fine with either Mobil 1 products and they are BOTH Dexos 1 approved. If you are changing your oil out according to the GM OLM and the intervals are at 7,500 miles, Mobil 1 0W20 is MORE than adequate for your use and it's MUCH cheaper at Walmart than Amsoil is.
The OLM monitors the motor rpm's among other things. So each truck will be different. For some who drive mostly highway miles, the OLM exceeds 7,500 miles. For those who use Amsoil, Blackstone has sent back reports that extends far beyond the recommendations of the OLM under certain conditions. So, what some guys do is reset the OLM even though it really doesn't need an oil change according to Blackstone. That way GM cannot say you didn't change your oil according the OLM.
The above info is gathered from a Silverado Internet site I frequent.
