I have a Jeep Grand Wagoneer with an AMC 360 V8. This engine was rebuilt roughly 20k miles ago and runs/sounds great. It has an "RV-style" cam, but is otherwise stock.
These AMC V8s never have the best hot idle oil pressure, mostly due to oil pump design, and I generally see about 15-20psi at hot idle (600rpm in gear).
Because of this, I don't want to go below an xw40 oil.
The other issue I have is that these oil pumps can be a little slow to prime, meaning I can get a momentary dry startup/delayed pressure build if I use anything with too high an initial number.
Considering the fact that it's carbureted, which increases the chance of oil dilution from fuel, I'd like to stick to the thicker side, which means I'll likely choose something on the higher end of 10w40.
I know there's a lot of talk about ZDDP in flat-tappet engines. I've never worried about this too much in my Jeeps with the 4.0, but want to be a bit more cautious with this one.
I'm looking for some opinions on this - am I on the right lines, and how much should I really be worried about the ZDDP level?
Also, some oils that meet my criteria are 4T motorcycle oils - is there any harm in using these?
