AMC V8 Oil?
Plymouth, UK
I have a Jeep Grand Wagoneer with an AMC 360 V8. This engine was rebuilt roughly 20k miles ago and runs/sounds great. It has an "RV-style" cam, but is otherwise stock.
These AMC V8s never have the best hot idle oil pressure, mostly due to oil pump design, and I generally see about 15-20psi at hot idle (600rpm in gear).
Because of this, I don't want to go below an xw40 oil.
The other issue I have is that these oil pumps can be a little slow to prime, meaning I can get a momentary dry startup/delayed pressure build if I use anything with too high an initial number.
Considering the fact that it's carbureted, which increases the chance of oil dilution from fuel, I'd like to stick to the thicker side, which means I'll likely choose something on the higher end of 10w40.
I know there's a lot of talk about ZDDP in flat-tappet engines. I've never worried about this too much in my Jeeps with the 4.0, but want to be a bit more cautious with this one.
I'm looking for some opinions on this - am I on the right lines, and how much should I really be worried about the ZDDP level?
Also, some oils that meet my criteria are 4T motorcycle oils - is there any harm in using these?
Mobil 1 0-40!!
Flows fast at start up. Nice oil film from start up to full temp.
The analysis I've seen seems to show that Mobil 1 0w40 is a little thinner at operating temperature than I would like, which is why I'm looking for something at the upper end of the 40 range.
Ideally I'd like an oil with a narrower viscosity range to avoid breakdown.
That oil has stable VII. Unless your engine has a severe problem with mechanical shear it will work fine. Most engines do not overly shear the VII.
Also it’s about the HT/HS and this oil is more than sufficient. It has Porsche A40 approval and that is a very demanding approval. Fine-tuning the viscosity within a grade is a useless exercise. If you want a higher HT/HS then use a 50-grade.
I should add, unfortunately Mobil 1 FS 0w40 is not so reasonably priced where I live - it looks like it'll cost me about $110 for one oil change!
Can't get it from Amazon, eBay or Walmart?
That was the first oil that came to mind when you asked and now see other people mentioned it too.
Then get Castrol Euro 0W-40, Pennzoil Euro Platinum 5W-40, Motul or Valvoline Euro 0W-40.
It's interesting that there is a rumor on here that Mobil 1 FS 0W-40 shears quickly out of grade and at the same time I know at leat a couple people who use it for years with great results.
Is there a Walmart in the UK?
Thank you all for the advice. Importing oil is difficult and prohibitively expensive. Mobil 1 0w40 is available here without importing it myself, just also very expensive.
I'm also a little put off after reading UOA of Mobil's 0w40, because each one I have seen seems to show it operating at the upper end of the xw30 range.
I will find an alternative!
I come back to my original question though - how much should I be concerned about ZDDP levels for an engine with a flat-tappet cam? There are many varying opinions out there. Hitorically I have just trusted that modern oils are better than old oils, and that the ZDDP in an oil with up-to-date certifications is likely replaced with alternative substances to perform the same job.
How true is that?
My old brain tells me AMC specified a minimum idle oil pressure of 10 psi with SAE 10W-30 oil. The big 3" thick factory maintenance manual stated 4 psi was minimum required to keep the mains and rod bearings lubed at idle. Hence, the low pressure idiot light switch. Used to have a 360 in a Jeep and my parents had one in a sedan.
How true is that?
No. Flat tappet engines only need increased ZDDP during break-in or if the spring pressures are excessive. You have neither. An ACEA A3/B4 is perfect for your application.
Find one there, buy it, use it.
