Here you go folks. Glad I stopped driving it and am getting it sorted. Bummer as I just filled it a few weeks ago with a fresh change of HPL 5W40 custom blend. This will end up with Liquimoly Leicthlauf High Tech 5W40 back in it which is fine. Clearly the source of the aluminum bits as well as elevated Al in my used oil analysis. It's rare to hear about issues with the timing chain tensioners/chains on the MK7/gen 3 vs. the previous gen 2.0 in the MK6 but I drive it hard so there you go.
From my trusted Euro shop:
Quick update. TLDR: it’s a ticking time bomb.
The timing chain tensioner is all the way out and has been cutting into the timing cover plug. You will need chains, tensioners, rails and the oil pan needs to be taken down to make sure there isn’t debris in it. Ideal time to upgrade to the aluminum oil pan as well. I have parts on order and will try to get you some kind of time and price estimate in the next day or so. I will not see all the parts until mid-week at the earliest and we leave for Watkins Thursday, but will try to expedite when we return because I know you have events coming up.
