Still has to flow through the ports? I’m mean if 2.4, 2.7 and 3.0 is enough of a difference to cause problems?Positive displacement oil pump ...
No, 2.4 vs 2.7 vs 3.0 doesn't make any difference to a PD oil pump.Still has to flow through the ports? I’m mean if 2.4, 2.7 and 3.0 is enough of a difference to cause problems?
So if a PD oil pump and the associated oil ports and passages can ensure sufficient oil flow at 0C when oil is cold and nearly 500x more viscous than at a temperature of 100C you mean to tell me the 15% difference between 0W20 and 5W30 is detrimental at operating temp? I’m just asking because someone stated they believed the issue was the engine was designed for 0W-16 and the oil passages/ports being too restrictive are the cause of this problem. I just don’t see how that could be true. Same goes for people who worry using 5W30 will have some detrimental effect on VVT. If VVT can accommodate cold oil it certainly can accommodate the difference between 20 and 30 weight oil.Yes it does ... and a PD oil pump ensures that happens, it forces oil volume and if it takes more pressure then that's what happens, the output pressure of the PD will just increase enough to put the same volume through the oiling system.
The PD oil pump ... so misunderstood.
It's not true - like I said, the PD oil pump will ensure proper lubrication. If it didn't you'd see so many blown up engines your head would spin.So if a PD oil pump and the associated oil ports and passages can ensure sufficient oil flow at 0C when oil is cold and nearly 500x more viscous than at a temperature of 100C you mean to tell me the 15% difference between 0W20 and 5W30 is detrimental at operating temp? I’m just asking because someone stated they believed the issue was the engine was designed for 0W-16 and the oil passages/ports being too restrictive are the cause of this problem. I just don’t see how that could be true. Same goes for people who worry using 5W30 will have some detrimental effect on VVT. If VVT can accommodate cold oil it certainly can accommodate the difference between 20 and 30 weight oil.
Agree!It's not true - like I said, the PD oil pump will ensure proper lubrication. If it didn't you'd see so many blown up engines your head would spin.
Anyone who believes running a thicker oil (within reason) is going to be harmful hasn't read enough threads on BITOG. How many threads have we seen where the same engines used around the world specify a large range of oil viscosity, and only specify one (driven by CAFE) in the USA .... ??
Bone up on PD oil pumps ... seems to be a very misunderstood thing on BITOG when it should be one of the least misunderstood thing about an engine oiling system.
Yes, VVT systems can accommodate cold oil just fine. Cold engine, cold coolant temperature, cold oil, the engine will run just fine.If VVT can accommodate cold oil it certainly can accommodate the difference between 20 and 30 weight oil.
Type-O...E is next to TWhat is RGT and RGE?
I use RGT 5w-30 and RGT 5w-20 regularly in the 11 fleet vehicles I take care of. Not a single one with oil consumption issues and they are all ran for a minimum of 6K miles, usually closer to 8-10K. As far as the tint, there's a lot of different oils that will have a reddish tint to it when draining. I've seen the same thing with Castrol and Valvoline. If your oil is "coal black" after 3K miles (especially as stout an oil as RGT) then the cause for that is likely due to your engines, it's definitely not a common thing for that oil to be "coal black" after 3K miles. Blaming the oil is jumping the gun a little bit here. Especially if you don't even get a UOA. Speaking of which, I am headed out here shortly to do fleet maintenance and I'll be getting UOAs on 5 vehicles all running RGT. I'll be posting those to the UOA section when I get them back.I take care of 8 cars. I, too, stocked up on RGT when it was $10/gal. 2 of the cars starting using oil at an alarming rate.
The Camry used 2 qts in 3500 miles. I know because after I drained it I noticed the oil pan was really light. So I measured
it and there was only 3.25 qts in the oil pan.
I also noted that when I drained the RGE it has a red tint to it as I watched it drain out. The oil in every case was coal black.
Coal black with a red tint. You saw the red tint when it was draining out and on the paper towels used for wiping up.
Remember, I change every 3k. I don't normally check the oil as I change it so often. Before the oil was still brown at changing.
Anyways, I am going back to what I used before. Thank goodness my mechanic is taking the RGT as a credit for future work.
I got 6 cases of gallons plus 3 single gallons.
Yup, and even though there can be less of difference between a thick 20 and a thin 30 than there is between a thin 20 and a thick 20 they believe it will be a problem.one thing i always note is a xx- 20W can be from 6.9 to 9.3 from shells specs anything more its a xx-30 so there can be very LITTLE-VERY LITTLE viscosity difference between thick 20's + thin 30's
I ran RGT for a few intervals of up to 7500 miles and never went below the full mark.I take care of 8 cars. I, too, stocked up on RGT when it was $10/gal. 2 of the cars starting using oil at an alarming rate.
