Hi,
I needed a alignment pretty bad after replacing the CV, so i stopped over at the local Mavis Tire..
Before Front:
Camber Left-1.0°(0.5° to -0.5°) Center -0.4°(-0.7° to 0.7°) RT-0.6° (0.5° to -0.5°)
Caster
Left 1.8°(2.4° to 1.0°) Center 0.0° (-0.7° to 0.7°) RT 2.2°(1.0° to 2.4°)
Toe:
Left 0.17° (-0.10° to 0.10°) RT 0.73° ( 0.10° to -0.10°)
Before REAR
Camber
Left-0.7° (0.3° to -0.3°) Center 0.0° Rt -0.7°(-0.3° to 0.3°)
Toe
Left 0.52°(-0.15° to 0.15°) Center 0.03° (-0.30° to 0.30°) Rt 0.49° (0.15° to -0.15°)
Total Toe 1.01° (-0.30° to 0.30°)
Thrust Angle 0.01° (-0.15 to 0.l5°)
AFTER FRONT
Camber Left -1.0°(0.5° to -0.5°) Center -0.5°(-0.7° to 0.7°) RT-0.6° (0.5° to -0.5°)
Caster:
Left 1.8° (2.4° to 1.0°) Center -0.3°(-0.7° to 0.7°) RT 2.2° (1.0° to 2.4°)
Toe: Left 0.01°(-0.10° to 0.10°) Rt 0.02°(0.10° to -0.10°)
AFTER Rear:
Camber
Left-0.6° (0.3° to -0.3°) Center 0.0° Rt -0.7°(-0.3° to 0.3°)
Toe
left 0.53°(-0.15° to 0.15°) Center 0.03° (-0.30° to 0.30°) Rt 0.50° (0.15° to -0.15°)
Total Toe 1.02° (-0.30° to 0.30°)
I called them, and they will look at it tomorrow, but whats up with the rear? the front is also off, the wheel is at 8&2 , give it 9&3 and you go right in a hurry. It pulls to the left and right, all depends on the road.. ugh..... What should i ask them to do? They did not adjust to much..
Red means out of spec, green is in spec... too bad its mostly red..
Thanks!
Before Front:
Caster
Toe:
Before REAR
Camber
Toe
AFTER FRONT
Caster:
AFTER Rear:
Camber
Toe
Thanks!
