So today I bring the car in for the camber kit install, and paid $100 after tax and things, on top of the $80 or so I paid last time for the alignment.
What I can say is after the camber kit install and realignment, the car is no longer pulling to either side (not a huge amount at least, but consider the Corolla is not a very sharp handling car to begin with, it isn't much of a problem and is well within my acceptable range).
What I noticed before and after in the reading is that those "way off" numbers before and after are very different: 6 degree in SAI, 7 degree in Included Angle, 0.6 degree in rear toe (was ok before and way off right after the camber kit, until the alignment), and 0.6 degree in total toe (was also ok before and way off right after the camber kit, until the alignment).
Now that I am paying more attention, I noticed that the time on the original alignment sheet and the time they test drive the car (immediately prior to me picking it up) is about 5 hours. They told me they tried to install the camber kit but found out that they have a mislabeled part in the box, so it won't fit.
My suspicion is that they want me to come back to add the camber kit, so they intentionally or accidentally screw up the alignment after they found out they have the wrong parts, so that I have to come back and let them do the work. How else could you change the toe on the opposite corner of the car so much with just a camber kit on? Taking an alignment measurement and giving the car back to the customer with different result is just "wrong".
Before
After
