Hey,
I was just up at Tires Plus getting my 76,000 mile Firestone Destination A/T tires replaced and had them check the Alignment.
'03 GMC Sierra 4x4 139,000 miles - never been aligned.
The tires wore even with "little" cupping on the front, other than that, perfect, not uneven!
Here's the results:
Front Left:
Camber: -0.5 Spec -0.3 to 0.8 degrees
Caster: 2.0 Spec 2.8 to 4.8 degrees
Toe: 0.18 Spec -0.5 to 0.15
Front Right:
Camber: 0.3 (good) Spec -0.3 to 0.8 degrees
Caster: 2.0 Spec 3.1 to 5.1 degrees
Toe: 0.4 Spec -0.5 to 0.15 degrees
Front:
Cross Camber: -0.8 Spec -0.5 to 0.5 degrees
Cross Caster: 0 (good) Spec -0.8 to 0.3 degrees
Total Toe: 0.13 Spec -0.10 to 0.3 degrees
What do you think? Get an Alignment or leave well enough alone...??
Thanks!!
Here's the results:
Front Left:
Front Right:
Front:
Thanks!!
