Hello all. I recently relocated to Anchorage AK from Atlanta GA and thinking about (and over thinking) oil for my land cruiser. '91 4.0 3fe ancient tractor motor. 208k miles. Stock 4.11 gears on 35 inch mud terrain tires so the motor is working hard. Currently it has Valvoline 5w30 conventional in it and is great for our warm summer right now however it seems to get a little better oil pressure with a 40wt.( Still fine with the 30 though.)
Here's what I'm trying to do: Find an oil that's suitable year round that has lots of zinc, in a 40 wt, with great cold weather performance, AND a high mileage formula to "possibly" combat some of the very minor weep/leaks I have before they get worse.
I have a block heater(freeze plug style)/oil pan heater/and battery blanket for winter and overnight it will be plugged in most nights but not all. I drive all over the state so overnight lows could be -50 F below outside of Fairbanks/Tok/Eagle in the interior and I may or may not have a place to plug in.
Ideally if Mobil 1 just made a high mileage 0w40 I wouldn't be making this post. Zinc over 1000 ppm already, excellent cold weather performance and a 40 wt at operating temp. It just doesn't have the high mileage additives that I'd like to start seeing if they can help the seals.
Mobil 1 10w40 HM has high zinc over 1000 ppm, 40wt, high mileage additives, low pour point from being Full Synthetic yet still I wish it was a 0w40 or 5w40.
Defy 10w40 has the zinc, high mileage additives, but cold weather I'm worried about.
Maxlife 10w40 doesn't have the zinc over 1000ppm, but a 40 wt with high mileage and still worried about cold weather startup.
You can see my thought process here and I'm hoping some of the gurus on here can help me narrow it down.
Thanks
Thanks
