I’d like to install a filter minder on the factory airbox on my 2012 F150. Best one out there? Wix, Donaldson?
In that case we'll all have to give up torque wrenches and wind up clocks.Also, any spring plunger thing will be vague of action except at the extremes of its travel.
... and many other pressure gauges, weighing scales, force gauges, etc.In that case we'll all have to give up torque wrenches and wind up clocks. ...
I think these Filter Minders are very useful, I've been running 1 on my 2011 Expedition for 6+ yrs.I’d like to install a filter minder on the factory airbox on my 2012 F150. Best one out there? Wix, Donaldson?
Meant to reply to your original note above...let me know if you have any questions, but I think that ^ might be a good option for you.I’d like to install a filter minder on the factory airbox on my 2012 F150. Best one out there? Wix, Donaldson?
The Napa #4801 filter minders have worked very well for me. They have been installed on my and some of my family's vehicles for over 10 years now if no sign of leakage or other problems. I have never changed an air filter since the installation of the gauges but I do check the air filter seals for resiliency, vacuum out the plastic air box and wipe the sealing surfaces with a damp cloth every year or two. As far as installation, I used an 11/16 spade bit. Drilled the hole in warm weather when the plastic was not brittle and checked the inside of the box to be sure I missed stiffening ribs. Try it . Installing differential pressure gauges on vehicle air filters is a win-win situation with both an accurate way of determining filter life and a method of utilizing the improving air filter efficiency (therefore engine life) as the filter loads.Nobody should be a "negative Nellie" for posts like this but I just gotta say.......
Those spring tensioned plunger things don't impress me. You bore a hole through a intake part and install a plastic thing. There's no telling the quality of the plastic thing. Plastics change dimension and embrittle with time. When it cracks and falls away you're left with a hole.
Also, the duty cycle of air filters is so long you'll be checking the plastic thing over 30,000 miles during which time the spring, also of questionable QC, might be changing.
Also, any spring plunger thing will be vague of action except at the extremes of its travel. When it decides to "go into the red" is something I bet isn't calibrated.
One last guess is based on my personal biases; little plastic contraptions which fall into the trinket category are things the assembly line people can't really care about.
Since AFCIs weigh in at around 30K (10K when in smoke conditions) I decided to go with simply changing the element. An extra air filter or two over the ownership of a vehicle is a small differential to pay vs drilling a hole and trusting some toy part.
Hey, if I'm wrong, I'm wrong, but I don't see the world lining up for these flow meters.
The Phaeton didn't have a bypass for when the screen is blocked, like my lowly Golf TDI?My Phaeton had filter restrictions gauges from the factory.
Handy for knowing when the snow screens were blocked.
No bypass. The screens were nasty when I got it. New filters showed 50% restriction.The Phaeton didn't have a bypass for when the screen is blocked, like my lowly Golf TDI?
I eventually ditched the snow screen by cutting the screen out and replaced the filter with a cold weather filter
