New to board, I hang "out" on the Impala forum but, have been directed by numerous folks to y'all for "answers"....thanx in advance and I'll check posts or e-mail me dirct! Jeff
?#1 1996 Chevy Impala SS,..show/cruise car, only 9400~ miles, "garaged/covered less than 1000 annual miles", many "bolt on's and PCM changes" but "stock motor", Iron head LT-1, virtually always run minimum of 20+ minutes or longer, usually only weekly~ May-September and for an hourish every 6 weeks during "storage" at various RPM's etc.,sees 5K RPM and "hard runs" occasionally.....moderate climate, rare to see 90'F, just as rare to be below freezing...due to "time contraints" and laziness and my local "jobbers" etc., I have easy access/use only Mobil One (M1)oil and choice of either Delco, Delco Gold (UPF), Purolator (standard or Pure One) or OEM filters. Available M1 oil weights are: Ow-30, 5W-30, 10W-30, OW-40, if possible prefer 5w or 10W -30 since gallon jugs are availble at considerable savings....Oil stays "golden" for about a year+, no consumption: Should I use M1 5W-30 or 10W30? (or other weight?) I like the Delco UPF filter, is there a "slightly longer" UPF filter that I can use to slightly increase oil capacity? These motors are pretty "stout" but "oiling volume" sems more important then "pressure"..Any problem w/ my "extended time" change intervals (1-2 years)? w/ low miles and consistent "warm-ups" of engine operation at normal temps?...
Car #2 2003 Mazda Miata, 1.8L dual cam 4 cyl..gently driven about 6K~ miles year, occasional but, rare burst to 6500+ rpm.. often "short trips of 2-10 miles", (same climate as above), gets to noraml operating temp for about 15 minutes daily, rarely used for long trips, always given a 1-3 minute "warm-up" in am's, garagaged...drained oil at 2500 miles, replaced w/ Penzoil 5W-30 and Pure One filter and will change to M1 5W-30 at 5K miles w/ recommend Mazda "severe service" 5K intervals of oil and filter change thereafter, lots of valve clatter w/ stock mazda filter AND Pure One filter and 5W-30 oil for 2-5 seconds often when "cold started", noticed Mazda dealer and Purolatoer just changed "recommended filter number" few months back (?), (perhaps ADBV issue w/ the valve clatter at start up?) Question is: M1 5W-30 w/ Pure One filter ok or go with Mazda, AC Delco (standard) or OEM filter?
?#3 1998 Toyota Solara 2.2 4 Cylinder/auto trans, 75K~ miles, well maintained but, spouses car, driven in same climate (but, "gently") under all conditions, synthetic oil/premium filter w/ 7500~ intervals since new w/ 3750 mile dino oil change/filter to 7500 miles to assist "break in"..modest consumption of 10-20 oz per 7500 miles on 5W-30 synthetic except about double that (1+ quart per 7500) when driving long, hot highway travel (to/through California)..No drips, no rattles, smooth idle, etc.,...clean under valve cover, Am I ok w/ M1 5W-30 and Pure One filter /7500 intervals? OEM or Delco (standard) filter instead or stick w/ Pure One? Should I be thinking of different oil weight when traveling to/through California on highways, especially in summer (75mph, using a/c, 3hours at a time)?
Prefer M1 oils in 5w-30/10W-30 since the jugs are cheaper than other weights by the quart but am open to suggestions, Redline, Amzoil just too costly, diddo for the Delco UPF filters/Mobil One filters EXCEPT for the Impala SS...e-mail me or post and THANX! Jeff in Western WA...
