This has been posted on a couple different Toyota sites I frequent, so I figure its fair game to lift and paste here for your reading entertainment:
"I own a 2001 corolla S ATM. I ran Seafoam through TB and let sit for a while. I started the engine up and instantly got a tick or nock that seemed to be coming from the valvetrain. At this time is showed no trouble codes. After about 300 miles and two days later it showed P0302, misfire in cylinder #2. I checked through tons of forums and videos and how to's. I have basically done them all except open up the engine. I have used Rislone to increase the oil pressure to help the hydrolic lifters(later found out the it is not hydrolic but solid and adjusted by shims), ran 1 quart of ATF through engine oil(ATF is a strong detergant) to get varnish off of lifters/valvetrain, ran degreaser through brake powerbooster vacuum line, ran seafoam again through the brake boost vacuum line, swapped ( one at a time to see if code popped up) coil #2 with #1(different banks) and injectors #2 with #1, sprayed two cans of Carb cleaner around vacuum lines and engine to find leaks(NONE), cleaned MAF sensor, Cleaned throttlebody, Check all four spark plugs. These all ended in a P0300 ONCE AND P0302 EVERYTIME AND KNOCK IS STILL PRESENT.
Guys i am at a loss, I am guessing i have a real issue. If i am correct, either i have some serious valve issue on cylinder#2 or worse a rod knock. What do you guys think?"
Thoughts?
Thoughts?
