JHZR2
Staff member
My primary concern is degradation of the MoS2 in an engine that is known to dilute some fuel and run hot. MoS2 shows SO2 offgassing, starting around 550K in a hydrated/oxidizing environment (see fig 12, http://www.dtic.mil/dtic/tr/fulltext/u2/a203741.pdf). Yeah, that's higher than the oil temperatures seen even in an N54, but that engine does dump a lot more thermal energy into the oil.
Second, fuel dilution must be considered for surface destabilization of suspended MoS2 particles. There could be a reaction or effect on the surfactant/surface treatments due to fuel. Common diesel dispersant packages, which are likely similar chemistries to what would stabilize the MoS2 particles can be destabilized and degraded in other oxidizing environments (http://papers.sae.org/2008-01-2375/)
I had added some of the LM Ceratec to the wife's VW rabbit last oil change. Standard, correct dose. The car developed an oil leak from the filter gasket, and not implying that this stuff caused it, BUT, I did find this:
So stagnant locations could build up these sorts of particulates which could make a mess too... Just a little concern, based upon what I saw, FWIW. Not trying to speculate on that here, but just adding the thought process here.
