I had driven ~1000 miles to the eclipse's path of totality in two days. I checked my oil level when cold out in the middle of nowhere and found it right in the middle, having started at about 3/4. It should have been reading a little higher than actual, as The Vehicle was slightly nose down at the time, so it had burned some on the drive.
I thought I had a spare quart of Mobil 1 0w-40 but all I had was a can of LM MOS2 that was half MOS2 and half Mobil 1 Turbo Diesel Truck 5w40 left over from a previous oil change.
While I knew I was in no danger of it running too low, Warm and fuzzies required I add it. Next day when hot, I noticed the engine was not idling quite as smoothly as normal, as normally I can't notice it.
Then I looked at my tach, and while the factory service manual says it should Idle at 750 rpm, for the last 7 years since I added the tach it has idled when hot in gear foot on the brake unmoving, at 525 to 550 rpm.
It now Idles at 500 rpm hot in gear foot on the brake unmoving. As hot as it gets, I have 22 to 24 PSI oil pressure at this 500 rpm with Mobil 1-0w-40. 65mph at 1900 rpm is 50 to 54PSI. Max cold is 68PSI, max PSI hot is 62 at 2400+ rpm.
It is a 1989 throttle body injected 318 controlled by the engine computer.
I am not saying the MOS2 lowered my Idle speed rpms nor claiming any magical properties of the product, just that the hot idle speed rpms in gear have lowered by 25 rpm after adding it. I am aware there could be other affecting variables, it just seems to have some rather direct correlation.
I expected the engine computer hold whatever Idle speed it decided to, and remain constant.
I know Mobil 1 0w-40 requires no additives and in general I am not an Additive type of person. I Noticed nothing when I bought and added half a can of the Mos2 3 years ago and added it to Mobil 1 Advanced Fuel Economy 0w30, and forgot I had half of it left.
Average Fuel economy over the 2500 miles was pretty good for my Vehicle considering all the considerable elevation changes, before adding the Mos2 and Afterwards as well, Exceeding my expectations by ~0.5 MPGs for the ~2300 miles I acquired before the last fill up.
