A year of old E350 ownership
OH
On 10/4/14, we became the proud owners of a '94 Ford E350 with only 70K miles, which we bought at an Ohio state salvage auction for all of nine hundred dollars.
It happened that I knew this van and had driven it while it was only a couple of years old. I actually drove it to state salvage myself.
I knew that it had been well maintained and if it was a bit rusty I knew it to be trusty.
I was prepared to go fifteen hundred for it, but there was little other interest in the old beast. I may have actually bid myself up to nine from eight fifty:)
Anyway, we've only put a couple of thousand on it in the past year, since I bought it as a hauler and did not intend to use the thirsty beast on a daily basis.
It has been dead reliable, other than my having to replace the starter.
It starts easily after sitting for weeks at a time and does fine in a hard day of use.
We put nearly three hundred miles on it a couple of weeks back in helping one of our sons make a hundred mile move, for example.
The old dear never faltered.
Fuel economy has averaged about 15 mpg, which seems pretty reasonable for a large, heavy vehicle with a 351W.
As I said to my wife, this thing is like somebody had supersized an Aerostar.
It drives a lot like a larger version of an Aerostar, although the IFS is entirely different.
Like an Aerostar, it has no special affection for going in a straight line, nor does it like bumpy roads.
We put a little over 175K on our '97 Aero with no problems beyond the starter replacement it too needed.
I doubt that the E350 will see anything like that kind of mileage, but it has been as trouble free thus far.
I've always said that Ford builds the best trucks.
The Aerostar was a truck among minivans, while a one ton van like the E350 cannot be regarded as anything other than a truck.
A good vehicle overall.
If you need a hauler and can find one cheap, an E350 would be a good choice.
I had a '94 E250 work van, 351 modified, E4OD like yours-it had only a few weaknesses:front suspension was prone to excessive positive camber when loaded-a good alignment & cam bushings fixed that. It also had an annoying tendency to burn ATF on long trips in O/D, especially when towing (usually only 2K-2500 pound trailer), and had stopped-up EGR passages in the intake manifold that caused CELs. Otherwise, it was a good van to 185K when they sold it.
Unless it was swapped in a 94 would have a 351 Windsor not a 351M. The 335 series engines were discontinued in the 80's(82 I believe). 15 MPG sounds pretty good to me for a one ton van. The Econoline series were real work horses for many years. Their time may be gone with better new replacements on the market for fleet use but for an individual looking for a used work vehicle they're still a solid option.
When still in Detroit we picked up an e350 for 1200 bucks. A 96 iirc.
I had that can completely loaded with tools including an alum break on the roof. It was our everything Van.
I had everything in it. From trim tools to framing tools to plumbing stuff and whatever else. It was for deficiencies. Made sure we never had to go get anything.
I put 200000 miles on it. It already had 150000 miles on it. Basically all city miles fully loaded,with the odd trip on the expressway.
Never had an issue with the van whatsoever. Still ran beautifully when the rust finally finished it off. I wasn't driving at the time but I guess it was catastrophic. The floor gave way or something. Rear end ended up breaking loose,while heading down the I-95 at 80mph.
No injuries. Luckily. Lots of nails were lost though.
One of our customers and friends at the shop just bought a '99 E-350 Super Duty with a 7.3 Powerstroke. I hate vans, from the perspective of working on them, but the Econoline is a proven workhorse. Not surprised to hear you're having good luck with yours.
Hmmm, that's odd it's not listed in your signature on here.
Ran out of room.
We also have the E350 and a '99 Subaru Legacy AWD 2.2.
The E350 has QS Advanced Synthetic (old API SM stuff) 10w30 and the Legacy has Mobil 1 High Mileage 10w30.
The BMW will get this Mobil 1 High Mileage oil next.
It seems miraculous in stopping leaks, maybe even better than the Maxlife I found to be so good in the old BMW.
We have all sorts of roofers and tradesmen using the exact van (down south of where you are). They buy them in the exact shape yours is in and drive them another 10 years. rust seems to be the only limiting factor. Homedepot parking lot is full of these at 09:00 am on a weekday.
Originally Posted By: Miller88
Cheaper and probably more useful than a pickup.
My thoughts exactly.
I wanted a heavy hauler that would protect the payload from rain, theft and blowing out.
I also wanted a vehicle that had the GVWR to safely transport everything you could stuff in it at highway speeds.
You get both with a ton van.
You get neither in a pickup.
You also can't touch a full size pickup in turnkey condition for 3X nine bills, much less one that's been well maintained by an ASE master with only 70K.
I'm happy with this purchase.
This generation of E-Series, as in '92-'96, not even counting later updated models, is super common around here. Even mid '80s-'91 models are somewhat common, though usually as box vans or lightly driven church vans. The cargo ones are mostly gone, but I still see them occasionally. The E-Series platform is very durable and flexible.
What I mean by flexible...
