Originally Posted By: TimVipond
Pretty good. Especially for those using or considering using an API SM, CJ4 or non-JASO oil in their motorcycles. "You should always use a motorcycle oil in a motorcycle, especially one that meets the required specification, such as the JASO-MA or MB and others, since the motor oil has in most cases a dual purpose of lubricating the gearbox and some have to deal with a wet clutch."
Someone is going to have to explain to me two things:
1) Why API states that "SM oils are designed to provide
improved oxidation resistance,
improved deposit protection,
better wear protection, and
better low-temperature performance over the life of the oil."
2) Why the UOAs of Rotella 15W-40 Triple Protection (SM rated) keep coming back with perfectly good wear metals, viscosity retention and TBN when run in shared-sump wet-clutch motorcycles?
As to #1 ... is it being suggested that the folks at API are selling snake oil? That what they say are mere words? That companies like Shell are lying when they report improved performance of their CJ-4/SM over the previous rated oil?
As to #2 ... this is why I posed the question in this thread:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1023524#Post1023524
My basic question was -- "Is it possible that increased wear wouldn't show in a valid UOA?" It seems the author of the article linked in the original post of this thread concedes the value of UOAs as that was going to be one of the basis points for their testing. So if the UOAs of an SM oil like Rotella Triple Protection keep coming back good, does that mean that the oil is working? Or that the UOAs are lying?
