The “amazing“ stories of A-10s taking damage and returning to base are all MANPADS or small arms hit. The typical SA-7/14/16/18 has a 3lb warhead. Better than an RPG, but an order of magnitude less than the warhead on a AA-10 for example.
Hmmm… so, too expensive to buy in numbers, you say?Well, the F-35 is far too fragile to use for ground support, it's gun still doesn't work, and the gun only has a few seconds worth of ammo. Any dent or hole from battle damage ruins it's stealth coating, and even a stealth aircraft isn't invisible and can be tracked/shot down via visual or infrared guns/missiles. Also, they are too expensive ( at over $100,000,000 a copy) to risk on 'tank-plinking' missions. Against a peer enemy neither the F-35 or the A-10 stands much of a chance surviving ground-strafing missions, both planes will have to use longer range standoff glide bombs/missiles for ground support, and a glide bomb/missile couldn't care less what kind of airplane wing it gets dropped or fired off from, so why not use A 10 wings that are bought/paid for long ago? . The A 10 has been upgraded a lot over the years (including expensive new wings/electronics) so it makes sense not to throw that investment in the trash, it's a mature, proven platform, it's much more rugged for harsh austere battle conditions, no fragile, high maintence stealth coatings to be compromised and far less vulnerable to hidden software bugs and enemy hackers. It's vastly cheaper to operate per flying hour. Moreover, the F 35 is still far too expensive to acquire in substantial numbers, the vast majority of the airforce still is and will be 1970's vintage F-16s and F-15's. You can see this in the Ukraine-Russia war, how quickly Russia burned through their top-of-the-line missiles/tanks inventories and are mainly using 1960's-1970's vintage gear now, and that war is small potatoes compared to a USA/NATO vs Russia war, where both sides would quickly deplete their 'modern' gear inventories and would degenerate to using stockpiles of 'vintage' gear....at least 'vintage' gear is better than no gear!
Pretty sure they’re TF-34This thing needs an engine update, those TF-30's are getting old.
If you've got those airplanes flying cover, they can deliver the weapon. Big duplication of effort to cover an airplane with another airplane.I would think there is a place for the A-10. Slow flying can more easily, observe, pick out, and hit ground troops and targets. If needed, I would think the AF can give them overfly cover with F 15's, 16's, 35's, whatever is needed to get the A-10's weapons, accurately, on the ground targets. .02
Affirm.Pretty sure they’re TF-34
Good points.If you've got those airplanes flying cover, they can deliver the weapon. Big duplication of effort to cover an airplane with another airplane.
It's like having a guy with an M-4 watch over a guy with an M-9. Why not have the guy with the M-4 shoot the bad guy?
What's the point of having the A-10 deliver the weapon, if you've got a weapon delivery platform overhead? Two airplanes to do the job of one...makes no sense.
There IS a place for the A-10: A combat area with no air threat, no surface to air threat, and tanks that need killing near an air base. But it's a one-trick pony.
Further, that scenario (permissive environment with bases near by) is really unlikely in future wars, and keeping the A-10 in service costs billions of dollars every year. Billions that could be spent expanding the capabilities of other airplanes.
Also, good points.But the guy who wants to have a taxi fleet does better with a couple dozen Corollas than a single Veyron. Eventually you have a bunch of airplanes that either you don't really have because they are so expensive there aren't enough to go around and you didn't get any this time or you have them and they sit on the ramp because they cost too much to risk losing them.
So, bugging your congressman is how the USAF should buy airplanes?The arguments over the A-10 are basically over the priority CAS (close air support) should have. The guys on the ground want CAS loitering within minutes of their position all the time. The parents of the guys on the ground want that CAS, too. They bug their congressmen about it, too. The air force, on the other hand, sees CAS as a secondary role. If F-16's and F-35's can eventually get the job done, more or less, then what's the big deal? So what if they have a small fraction of the time on station and have to come from air fields far away a lot of the time? The fast movers look so much better on posters and are way more fun to fly.
How many were shot down during Operation Iraqi Freedom? Or in Afghanistan?And, if the grunt can see the airplane, so can the enemy. the A-10 can loiter just long enough for them to get AA assets in place, even if something like a shilka
That’s precisely the point. None.How many were shot down during Operation Iraqi Freedom? Or in Afghanistan?
Right, LDB. Us Texas boys gotta hang together, lol. + U.S. ground troops seeing an A-10 in the area are gonna get a morale boost. I think we should have an "all of the above approach" re all these aircraft encompassing cost, availability, and performance.So the only answer is to employ something costing 20 times as much and only available in 20% of the quantity needed.
